14 bold ff end play
Discussion in 'The Garage' started by the general, Feb 24, 2007.
  1. the general
    the general Registered Member
    Oct 2, 2004
    96
    prinsenbeek(the Netherlands)
    :bow: who can tell me what the right endplay is on the 14 bold ff diff is?(ring+pignon endplay) are ther shims in the pignonaxle or is there a cruhsbushing are there shims between the mainbearings or how do you guys make this right?:confused:
    Patrick , The Netherlands
  2. readymix
    readymix 3/4 ton status
    May 30, 2004
    6,706
    26
    Murrieta, California
    Crush sleeve on the pinion in between the bearings.
    The shims go in between the pinion housing and the axle center section to set the depth.
    What are you meaning by "endplay"? If backlash then set it to around .008
  3. Slapperbar
    Slapperbar Retired Navy NDT Examiner Premium Member
    Nov 29, 2005
    2,747
    3
    Harrison City, Pennsylvania
    <whisper> Pssssst, Patrick. Its 14 BOLT </whisper>
  4. the general
    Oct 2, 2004
    96
    Yes readymix, that is what i ment, backlash(.008 inch? how much is this in milimeters?) i could not find the correct word thanks! ,so shims and a crushsleeve on the pignon. and no shims on the mainbearings (like on my 12 bolt rearaxle) how does this work? and Slapperbar also thanks for the correction!!(its not easy technical talking in a different language!!!)
  5. thatK30guy
    Jan 12, 2001
    32,076
    55
    You can say it out loud.......BOLT!!!
  6. readymix
    May 30, 2004
    6,706
    26
    .008 = 0.2032mm
    There are spanners to set the BL and bearing preload on a 14FF
  7. the general
    Oct 2, 2004
    96
    thanks guys fot the replies!!
  8. the general
    Oct 2, 2004
    96
    okay, its for the replies
