14 bolt? 2x same as 4x?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by CBLAZER81, May 26, 2002.
  1. CBLAZER81
    CBLAZER81 1/2 ton status
    Mar 3, 2000
    281
    Milliken,COLORADO
    My wife's uncle has a 2wd p/u with a 14 bolt rear end that I can probably get for free.I assume there's no difference between the 2wd and the 4x4 version but I just wanted to make sure.I don't need another piece-o-stuff laying around that I can't use on my rig.
    Thanks.
  2. riz
    riz 3/4 ton status
    Mar 7, 2000
    6,026
    Wisconsin
    <font color=blue> I believe they're the same ....
  3. Seventy4Blazer
    Seventy4Blazer 3/4 ton status
    Apr 21, 2001
    5,634
    Escondido, CA
    mine is off a 2wd, but just so you can see for yourself get a tape measure out and check it
    should be like 35 inches outside to outside or something
    grant
  4. Rebel88
    Rebel88 1/2 ton status
    Sep 7, 2000
    1,855
    Richmond, VA
    in my case the 2 wd shock mounts were too close to the axle tubes and had to be extended out so the shocks body wouldnt make contact
    Later
  5. BlazerGuy
    BlazerGuy 3/4 ton status
    Apr 20, 2000
    9,206
    abcde
    35"?! what measurement is that?
  6. thatK30guy
    Jan 12, 2001
    32,076
    55
    2wd shock mounts will sit down further away from the tubes.
    4wd shock mounts sit right with the tubes.
  7. Seventy4Blazer
    Apr 21, 2001
    5,634
    Escondido, CA
    i think that was the spring perches. not sure though. i go measure right now
    ok, 45.5 or so. tape was curved due to the centersection.
    not 35. thats outside to outside on the perch.
    grant
  8. Zeus33rd
    Mar 14, 2002
    7,324
    9
    Grass Valley, CA
    Yep, the 2 wheel driveshock mounts are different. The 12 botl in my truck came from a 2 wheel drive. Had to whack the mounts of and move'em up a bit. Sucked too, cause I thought I was all done with the axle swap...went to bolt up the shocks and.......ARGHHHHH!!!!!!!! lol. /forums/images/icons/crazy.gif
  9. Seventy4Blazer
    Apr 21, 2001
    5,634
    Escondido, CA
    there is a reason i wouldnt have known that....
    i removed the mounts and installed my own before it went under the truck..... oops!! now i know
    grant
