14 Bolt a JunkYard, I cant figure out ratio?
Discussion in 'The Garage' started by Scott A, Dec 27, 2003.
  1. Scott A
    Scott A 1/2 ton status
    Apr 18, 2002
    129
    Monrovia, CA
    I found it on a 2wd 76 Truck.
    I turn the tire 1 revolution and the pinon turns 2 times. Are there numbers on the pinon gear? I do see numbers on the ring gear.
  2. Seventy4Blazer
    Seventy4Blazer 3/4 ton status
    Apr 21, 2001
    5,634
    Escondido, CA
    what do all the numbers on the ring gear say? turning the tires is not that accurate of a way to tell.
    Grant
  3. Scott A
    Apr 18, 2002
    129
    Monrovia, CA
    I did'nt write them down. I am going back today. They want $119 for it.
  4. Scott A
    Apr 18, 2002
    129
    Monrovia, CA
    what should the numbers on the ring gear be for a 4.10?
  5. Confedneck
    Confedneck 3/4 ton status
    Nov 1, 2002
    5,236
    Lehigh Acres, Florida
    for 119 bucks? a 14bff rear axle is a good deal no matter the ratio..
  6. Beast388
    Beast388 1/2 ton status
    Nov 6, 2001
    3,039
    Clinton, IA USA
    On the ring gear you will find "41 10" or "41 11" as well as a long string of numbers. Those numbers are the number of ring and pinion teeth. You divide the larger number by the smaller to get the ratio. eg. 41/10 = 4.10:1 ratio. 41/11 = 3.73:1 ratio.
    As far as junk yard diffs go, the 4.10's and 3.73's are the most common. But whatever you find, just do the math to figure out what ratio you are looking at. /forums/images/graemlins/thumb.gif
  7. R72K5
    R72K5 Banned
    Mar 5, 2001
    8,905
    central IL
    also lok in glovebox for the RPO SPID label, it might lsit ratio, if is not the std ratio for the drivetrain put in it, but you never know it might have been swaped since 76, so yeah best bet is to pull the diff cover and look.
    good luck
  8. Scott A
    Apr 18, 2002
    129
    Monrovia, CA
    I got it for $119 out the door. And, if I give them my 10 bolt, I get $25 back. It's 3:73 Open. I got the u-bolts & plates too.
