14 bolt and 15" rims
Discussion in 'The Garage' started by OU812, Apr 11, 2002.
  1. OU812
    OU812 Registered Member
    Jul 12, 2001
    43
    Ca
    14 bolt and 15\" rims
    15" rims will fit over the drums of a 14ff wont they?? I want to order my tires and rims tomorrow.
  2. Hossbaby50
    Hossbaby50 3/4 ton status
    Sep 1, 2001
    8,972
    Peoria, AZ
    Re: 14 bolt and 15\" rims
    Yep. But you will have to grind the front calipers on a D44, 10 bolt, or D60 to get them to fit. Not a real big deal though.
  3. Esteban86K5
    Esteban86K5 1/2 ton status
    3,712
    Bakersfield, CA
    15" STEEL rims will fit. NOT aluminum. Just wanted to clarify a bit.
  4. OU812
    Jul 12, 2001
    43
    Ca
    even on the 44 huh? I dont think I will have a problem with that. Have you ever just had real good luck?? I picked up this Blazer 800 bones great shape d44 and 14ff for 200bones so I am in it for 1K just needs rotors and calipers and brakes now. God life is good
  5. OU812
    Jul 12, 2001
    43
    Ca
    I wouldnt even think about aluminum on a trail rig. Great point thank.
  6. Triaged
    Triaged 1/2 ton status
    Feb 21, 2001
    3,808
    CA (LA/OC area)
    I'm running 3.5" of back spacing and had to do just a little bit of grinding. I have seen the amount of grinding that it takes to fit 4.125" or 4.25" of backspacing and it scares me! The less backspacing the better IMO.
  7. ChevyCaGal
    ChevyCaGal 3/4 ton status
    Dec 16, 2000
    8,158
    Sacramento, CA USA
    Are you sure on a 10b you have to grind? I have 15" rims on mine and never grinded a thing and neither did the previous owner...
  8. wayne
    wayne 3/4 ton status
    Feb 1, 2001
    6,178
    Carlisle, Pa
    They fit. I have 15x10 with 4 1/8" backspacing on mine. It took alot of grinding on the D60 but the 14ff they fit with no problem.
  9. thatK30guy
    Jan 12, 2001
    32,076
    55
    Steph, I think Hossbaby was referring to fitting 15" rims on 3/4 ton axles. /forums/images/icons/wink.gif
  10. Esteban86K5
    3,712
    Bakersfield, CA
    Yeah Steph, He's talking about 3/4 ton 10 bolts./forums/images/icons/wink.gif/forums/images/icons/laugh.gif
  11. 72THING
    72THING 1/2 ton status
    Nov 26, 2001
    501
    Ranburne, AL
    I have 15x10 Rockcrawler Steel wheels with 2.5" backspacing. I only had to remove about 1/8" on the caliper where it meets the wheel. They work great.
    Will
  12. ChevyCaGal
    Dec 16, 2000
    8,158
    Sacramento, CA USA
    Makes sense but he didn't say 3/4 ton so how was I to know what exactly he meant? /forums/images/icons/smile.gif
  13. thatK30guy
    Jan 12, 2001
    32,076
    55
    LMAO!! /forums/images/icons/laugh.gif
    Well, the way I saw it...read the subject title..."14 bolt and 15" rims" makes it obvious he is talking about the 3/4 ton axles here. /forums/images/icons/wink.gif
