14 bolt and D70 axle tube size?
Discussion in 'The Garage' started by Poohbair, May 7, 2004.
  1. Poohbair
    Poohbair 1/2 ton status
    Jan 30, 2003
    2,139
    Ellensburg, WA
    Will the spring perches that are sold for a 14bolt work on a D70? The only reason that I could think that they wouldn't is if the axle tube sizes are different. Does anyone know???
  2. mofugly13
    mofugly13 1 ton bucket of rust Premium Member
    Oct 6, 2002
    2,813
    San Francisco
    My D70U tubes are 3 3/8"
  3. Poohbair
    Jan 30, 2003
    2,139
    Ellensburg, WA
    thanks, anyone know what a 14 bolts is??
  4. Beast388
    Beast388 1/2 ton status
    Nov 6, 2001
    3,039
    Clinton, IA USA
    3-3/8"
    /forums/images/graemlins/waytogo.gif /forums/images/graemlins/waytogo.gif
  5. Poohbair
    Jan 30, 2003
    2,139
    Ellensburg, WA
    NICE!!! So if I order some axle mounts for a 14 bolt they should go right on my D70!!! I like that!!!! /forums/images/graemlins/grin.gif
    Where is the best place to buy some spring mounts??????
  6. rnss82
    rnss82 Registered Member
    Mar 28, 2004
    22
    oregon,wa.
    my 14bolt ff tubes are around 3 5/16" hard to measure but hope that helps
    why dont you fab some up useing some square stock that is the same width as your springs and take a hole saw that is the same size of you r axel and cut a hole about half way in to the sq stock and weld them on
    /forums/images/graemlins/thinking.gif
  7. Beast388
    Nov 6, 2001
    3,039
    Clinton, IA USA
    If I were you, I'd verify that your D70 has 3-3/8" tubes. Some of the D70's were bigger. If they are, PM TonyP....he makes spring perches for the 14BFF. Or you could make your own.... clicky.
    I made my own similar to that article.
  8. tarussell
    tarussell 1/2 ton status
    Dec 28, 2002
    1,354
    Bagdad , FL
    Like said above - check your Dana 70 tube size . Not all Dana 70's are created equal . Many different tube sizes have been offered through the years and models of 70's .
    Tom
  9. boz42
    boz42 1/2 ton status GMOTM Winner
    Jun 3, 2003
    3,181
    Hopewell, Tn 38058
    my D 70 has 4" tubes. measure twice & order your parts once.
