14 bolt and dana 44 axles, help me please
Discussion in 'The Garage' started by LostChild, Apr 6, 2006.
  1. LostChild
    LostChild Registered Member
    Mar 28, 2006
    60
    PoeDunk Utah
    I got a 14 bolt FF rear rear axle with 4:10 gears and a dana 44 left hand drive flat knuckled 8 lug 4.10 gears line up through a guy here in utah that will sell me both axles for $200 buck will the front dana 44 axle swap straight into my blazer? I am in it for the rear axle but if I can get the front axle out of the deal with matching gears that swaps straight in I figure ROCK ON, Thanks for any help.
  2. Muddytazz
    Muddytazz 1 ton status
    Jun 30, 2002
    20,073
    Salem, Or.
    Direct swap :thumb:
  3. stallion85
    stallion85 1/2 ton status
    Jul 11, 2003
    3,659
    Cedar City, UT
    Easy as pie:) http://coloradok5.com/axleswap.shtml
    The only thing that might pose a problem is the rear driveshaft will need a conversion U joint and the e brake cables might not match with the 14ff....
  4. LostChild
    Mar 28, 2006
    60
    PoeDunk Utah
    so what would the conersion U joint consist of, ( sorry new the game )
  5. Masiony
    Masiony 1/2 ton status
    Sep 2, 2005
    729
    Springfield, OR
    instead of having the same sizes on all the caps, it has two different sizes. one set fits the (1350 i assume) yoke of the 14 bolt, while the other fits the (1310 i assume again) yoke on the end of your driveshaft.
  6. stallion85
    Jul 11, 2003
    3,659
    Cedar City, UT
    Correct, now if you have an SM465 and an 80's K5 you might be lucky and already have 1350 u joints in your rear driveshaft like I did....
  7. rick88blaze
    rick88blaze 1/2 ton status
    Jan 24, 2003
    2,342
    Knob Noster, Mo.
    Do you mean the differential is on the left side or driver's side of the truck? :confused: If so this won't be a direct swap on a '73 to '91 blazer. You need a passenger side differential Dana 44. :D
    Rick
  8. jones
    jones 1/2 ton status
    May 17, 2004
    379
    IONIA,MI USA
    he may even luck out on the u-joint issue if he's got a 700r.they use a 1350 at the pinion end and bolted up just fine when i swapped from 10b f/r to d44f/14bff.doing a comparison at the parts store confirmed this.
  9. LostChild
    Mar 28, 2006
    60
    PoeDunk Utah
    well I hope it all works out, right now the biggest problem I am haing is getting the guy to write me back, so I can go pick up the axels.:mad: :mad: :mad: :mad:
