14 bolt and Dana 60 ring gear #'s???
Discussion in 'The Garage' started by TruckNutzDude, Feb 27, 2004.
  1. TruckNutzDude
    TruckNutzDude 1/2 ton status
    Mar 31, 2003
    3,532
    Agawam, MA
    14 bolt and Dana 60 ring gear #\'s???
    Can you guys tell me my gear ratio and production date /forums/images/graemlins/dunno.gif Everything came from a donor truck and I believe both axles are originals. The weird part is that this truck wasn't a '72 (I'm fairly sure it was at least an '85 or '86) and Dana 60's didn't come out until 1976 right? HELP!!! /forums/images/graemlins/bow.gif
    14 Bolt ring gear reads:
    3992484 11 41 9 72 GM2
    And the Dana 60 is:
    10 1 71 DANA 34508 A3D33X 41-11
    The upper corner of the diff. housing reads: G40386
    Thanks guys
    EDIT BOM# on front reads
    61021 1 SJ4 6 13 4 8B
  2. Shaggy
    Shaggy 3/4 ton status
    Dec 15, 2000
    6,737
    Los Banos, CA
    Re: 14bff ring gear # question
    9 72 is likely the production date, but from your avatar pic that actually seems unlikely. It's going to be 3.73. Count the teeth on the pinion and ring and match them to one set of numbers if you want to be 100% sure, one guy in the club I'm in had an R&P that was stamped wrong. /forums/images/graemlins/shocked.gif
  3. TruckNutzDude
    Mar 31, 2003
    3,532
    Agawam, MA
    Searching didn't help much the second time either... can anyone else help me out so I know a little more about my axles?
  4. big83chevy4x4
    big83chevy4x4 3/4 ton status
    Mar 22, 2002
    6,587
    Sheridan, Michigan
    Re: 14bff AND Dana 60 ring gear # question
    11-41 is the gear count and 9 72 should be the casting date
    on the d60 10 1 71 is the casting date but they didnt have the d60 front until 76 /forums/images/graemlins/dunno.gif
  5. TruckNutzDude
    Mar 31, 2003
    3,532
    Agawam, MA
    that's my problem... I'll have to check the numbers again but I'm 90% sure that's what I saw /forums/images/graemlins/confused.gif
    are there any other numbers I can grab off the diff. to tell what year it's from? there are no numbers on the axle tube but there are some on the top of the housing.
  6. TruckNutzDude
    Mar 31, 2003
    3,532
    Agawam, MA
    nothing /forums/images/graemlins/1zhelp.gif it's really bugging me that I can't tell what year my axles are from.
  7. thatK30guy
    Jan 12, 2001
    32,076
    55
    1977 was the first year. /forums/images/graemlins/waytogo.gif
  8. Blazer1970
    Blazer1970 1/2 ton status
    1,600
    Old Mission, MI
    Re: Mysterious 14 bolt and Dana 60 ring gear #\'s???
    You can ID the 60 by the BOM number stamped on the front of the drivers side axle tube to the right of the pumpkin (as you are looking at it from the front). I would guess that those are not date codes on the gears.
  9. thatK30guy
    Jan 12, 2001
    32,076
    55
    I got a PM from Robert about this and told him about the BOM, too. I also mentioned to him the gears may have been swapped in if they are dated '71, since the D60 fronts didn't start in the GM line til '77. /forums/images/graemlins/thinking.gif
  10. TruckNutzDude
    Mar 31, 2003
    3,532
    Agawam, MA
    Maybe it says 77 on the gear and not 71? I'll go out and check again for the BOM it may be under all the sludge I missed with my wire brush the first time /forums/images/graemlins/whistling.gif
    And 3.73's suck!!! I knew this thing was a dog with the 38's /forums/images/graemlins/doah.gif
  11. TruckNutzDude
    Mar 31, 2003
    3,532
    Agawam, MA
    /forums/images/graemlins/woot.gif I found the BOM /forums/images/graemlins/woot.gif or part of it.
    61020 1 SJ4 6 13 4 8B not clear... maybe it reads
    51021 1 SJA 6 13 4 88?
  12. TruckNutzDude
    Mar 31, 2003
    3,532
    Agawam, MA
    a trip to the Dana 60 bible told me that this axle is either a 610201 -84-88 CUCV axle or a 61202 -84-85 K30 axle, either way it's not a 71 anything according to my numbers /forums/images/graemlins/thinking.gif did I get it right?
