14 bolt and h1 wheels..nothing in search..
Discussion in 'The Garage' started by k5 krawler 50, Feb 16, 2006.
  1. k5 krawler 50
    k5 krawler 50 1/2 ton status
    Jan 26, 2004
    1,467
    Gardnerville, NV
    hey, got a quick question, i have stock h1 wheels, and a 14bolt out of a suburban, i've searched but have come up with nothing really, does any one know what i need or should do to the 14 bolt, to run the stock h1 wheels. Thanks.
    Cory
  2. MTBLAZER89
    MTBLAZER89 3/4 ton status GMOTM Winner
    Aug 14, 2001
    7,272
    237
    Oak Harbor, WA
    Yeah you need Duallie hubs to run the H1's without recentering them. You will also need them for the front.
  3. 86Cucvbeater
    86Cucvbeater 1/2 ton status
    May 24, 2005
    428
    north carolina
    I've ran H1's on a 14 bolt ff without any modifications so u dont "need" dualie hubs on the 14 bolt. just fwiw
  4. MTBLAZER89
    Aug 14, 2001
    7,272
    237
    Oak Harbor, WA
    That must be pretty narrow. I meant you need DRW hubs if you want the track width to be similar to stock. H1's have a lot of backspacing to them. You couldn't run them "stock" on the front without some sort of interference, and that would look goofy to have the rear that narrow and the front normal.
  5. darkshadow
    darkshadow 1 ton status
    Dec 6, 2003
    12,250
    C-eh-N-eh-D-eh
    if the 14 is out of a burb it is a semi float, not sure of the width differance.
    IIRC the rear is already 2" narrower that the fron and the wheels have about 7" of BS so you wolud need about a 3-4" spacer and that would get you a standered 3-4" back spaceing.
  6. 78Suburban
    78Suburban 1/2 ton status
    Jul 4, 2005
    2,609
    Georgia
    Just for kicks and giggles, I reallly want to see some unaltereed h1 wheels on a 14bolt... must look super narrow from the back.. Wonder if those ever have trouble scrubbing on the inner rear fenders :eek1:
    thanks,
    James
  7. Greg72
    Mar 5, 2001
    15,684
    1,392
    642 Days to BB2018
    Here's a pic of unmodified H1's on a van-width 14BFF
  8. k5 krawler 50
    Jan 26, 2004
    1,467
    Gardnerville, NV
    Greg72, thanks for the pic, off the top of your head do you know what the wms to wms of a van 14 bolt is?
    Darkshadow, the 14 bolt i have is a full floater, and it did come out of a burb, i've seen burbs with sf 14 in them before, but i made sure before i got this one that it was in fact a ff.. thanks for the heads up thou.
    Also thanks to everyone else who responded. It seems that i will have to make some strong spacers to accomadate the crazy offset.
  9. Greg72
    Mar 5, 2001
    15,684
    1,392
    642 Days to BB2018
    Vans are 3" wider than a standard 14BFF...
    Don't be fooled by that pic. I have the H1s out back in that shot, but conventional 3.75" BS wheels up front. Unmodified H1's will NEVER fit on a SRW D60 without hitting the knuckles, tie rod and brake calipers.
    Even out back, you're going to probably need to "tub" the wheelwells if you want the tires to stuff underneath like in the pic.
    I got those H1s for free, so I was just playing around with them to see how it would look.
  10. k5 krawler 50
    Jan 26, 2004
    1,467
    Gardnerville, NV
    thanks for the info, i have dually hubs for my front 60, so that should work fine, i was just trying to accomadate something for the rear. Sorry but did you mean the van width is 3 inches wider a side, or total? Thanks again. Cory
  11. Emmettology 101
    May 9, 2000
    8,126
    FL
    Pat Vermillion used to run unmodified H1 wheels on a D60 under a Bronco.. I emailed him a few times and he said he didn't change anything. Other than I am sure he was running a highsteer/crossover arm that was made to run hummer rims... *shrug*
    And what is the track width of your front axle with the 3.75" BS wheels?? With the Van width rear and H1's, it doesn't look liek much of a width difference with the front. In the pic it looks similar to runn stock offset axles. Just wondering what it would be like with a DRW60 up front and H1's with the Van width rear and H1's....
  12. Emmettology 101
    May 9, 2000
    8,126
    FL
    A van rear axle is 3" wider total... Should be around 70" wms-wms.
  13. k5 krawler 50
    Jan 26, 2004
    1,467
    Gardnerville, NV
    Cool, thank you.
  14. 6.2Blazer
    6.2Blazer 1/2 ton status
    Feb 24, 2000
    4,675
    26
    Ohio
    A van width rear 14FF axle is 3" total wider, so it should have the same WMS to WMS measurement as a normal SRW Dana 60 front axle. If you switched to dually front hubs then the track width on the front would be wider by the width of the dually hubs. I don't know the measurement off hand but I know the front dually spacers on most new trucks is around 4-5" on each side........so the front axle would be 8-10" wider than the van width rear axle
  15. Emmettology 101
    May 9, 2000
    8,126
    FL
    No Problem! :thumb: I think the wide duallie axle(not C&C) is around 74"....
  16. Emmettology 101
    May 9, 2000
    8,126
    FL
    A DRW 60 front is 77.5" wms-wms... So that would make it about 7" wider than a van width 14ff... But looking at Greg's pics, it looks as if the difference between is SRW front with 3.75" BS wheels and the van width rear with H1's is only a few inches. I think a DRW 60 front with H1's is pretty similr width overall(outside of tire to outside of tire) to a SRW60 with small BS wheels...
    Is my thinking off?
  17. 6.2Blazer
    Feb 24, 2000
    4,675
    26
    Ohio
    I think the perspective of the pictures throws it off a little, you really need a picture looking straight down on top of the truck to compare so both the front and rear tires are equal distance away from the camera. The rear will be 3.25" narrower on each side, or 6.5" narrower total. I don't think the difference is terrible or anything, but probably very noticable considering the stock 1.5" difference on each side that stock trucks have is quite apparent.
    Based on the numbers you provided, a DRW front 60 with unmodified Hummer rims would be equal to a SRW front 60 with 3.5" BS rims (assuming these rims are the same width as the Hummer rims).
  18. sandawgk5
    sandawgk5 3/4 ton status
    Oct 28, 2003
    6,881
    Kitsap County PACNORWEST
    If you get a DRW 14FF from a pickup it should be about 74" wide. Then you take the hubs from a SRW 14FF and put them on the Dually axle this moves the hub flange out to approx 79" which is the width of a Dually 60 front. That way you can use factory axles and have the same track width front and rear. The only problem is you cannot run the factory brakes you will have to go disk and have custom brackets made. You can do the same with a Dana 70 DRW 14FF hubs will fit on those also.
    If you do not want to deal with the brake issues get a DRW like above and run spacers on the hub that way you can run the factory brakes and still push the WMS out to match the front.
    Ira
  19. Greg72
    Mar 5, 2001
    15,684
    1,392
    642 Days to BB2018
    More pics for reference:
    D60 Caliper hits wheel...
    Steering Knuckle hits on D60...
    High Steer Hits...
    Rear Stick Out with Wagonwheel (3.75" BS)
    Rear Stickout on unmodified H1 Wheel...
    Different angle to show Wagonwheel (front) vs. H1 (rear)
  20. bigjbear
    Feb 18, 2000
    13,973
    454
    Marietta GA
    Greg, for clarity, is that a SRW or DRW front? TIA.
