14 bolt axle diameter is 3 3/8" ???
Discussion in 'The Garage' started by TX Mudder, Nov 4, 2002.
  1. TX Mudder
    TX Mudder 1/2 ton status
    Jul 10, 2000
    2,514
    Houston
    14 bolt axle diameter is 3 3/8\" ???
    I thought that was the right measurement, but the spring shop I went to told me that it couldn't be 3 3/8, had to be 3 1/2. I almost bought a set uf 3 1/2" ubolts, but then I started thinking if that was such a good idea if indeed it is 3 3/8".
    Oh well, I have to go back to the spring shop anyway.
    I bought a set of longer Dana 60 ubolts....but forgot that two of the ubolts are smaller (only go around axle tube) and 1 is longer (goes around housing.) So now I two extra ubolts that I'll never be able to use plus I need to buy two ubolts that actually fit the Dana 60 tube.
    -- Mike
  2. thatK30guy
    Jan 12, 2001
    32,076
    55
    Re: 14 bolt axle diameter is 3 3/8\" ???
    Yes, it is 3 3/8" diameter. /forums/images/graemlins/wink.gif
