14 bolt Axle ID Number ?
Discussion in 'The Garage' started by SF87K5, May 22, 2003.
  1. SF87K5
    SF87K5 1/2 ton status
    Oct 27, 2002
    1,105
    Stedman, North Carolina
    I am tring to find if a 14 B FF had a ID number on it, and if it does where do I find it. I also was woundering what the website was that you can look that number up at. I am woundering what year and truck my rearend is off of.
    Thanks for all you help.
  2. MTBLAZER89
    MTBLAZER89 3/4 ton status Premium Member GMOTM Winner
    Aug 14, 2001
    7,272
    237
    Oak Harbor, WA
    There is a number stamped on the ring gear with the ratio and date of manufacture.
  3. SF87K5
    Oct 27, 2002
    1,105
    It dont have the original ring gear in it. /forums/images/graemlins/frown.gif
  4. MTBLAZER89
    Aug 14, 2001
    7,272
    237
    Oak Harbor, WA
    hmmm clean the housing up see if there are any numbers on it anywhere...should be something I would think
  5. Confedneck
    Confedneck 3/4 ton status
    Nov 1, 2002
    5,236
    Lehigh Acres, Florida
    do you have the axle ID tags still? if they are original they probably have a code that the gm parts department uses to decode things... ie year, model etc..
  6. K5MONSTERCHEV
    K5MONSTERCHEV 1/2 ton status
    Jan 27, 2003
    3,254
    Castro Valley, CA
    Mine has some numbers on the upper right side on the tube.
