14 bolt axle swap
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by t's85chevyk5, Jan 30, 2004.
  1. t's85chevyk5
    t's85chevyk5 Registered Member
    Jan 29, 2004
    66
    Phoenix, AZ
    Do i need to go with 16" rims to accomodate for the 14 bolt in the rear, or can i just use the 15" rims i have now with the 8-6 lug adapter?Also will my brake lines workfrom my 10 bolt to 14 bolt?
    thanks Taylor , phoenix az /forums/images/graemlins/k5.gif
  2. t's85chevyk5
    Jan 29, 2004
    66
    Phoenix, AZ
  3. woody9
    woody9 1/2 ton status
    May 27, 2001
    602
    Howell, MI
    not sure if you're talking a FF or SF...(SOME sf are 6 lug itink) but there are 8 lug 15" that will work. Depending on backspacing you may need to grind for the calipers I believe, but that may be for rear disc (personally, i went 16 on mine for other reasons)...
    My brakelines worked when I had the drums in back. (had to adjust some when i later went to disc...
    do a search on this, and you should find a slew of info
  4. mr_fujisawa
    mr_fujisawa 1/2 ton status
    Sep 1, 2003
    288
    SF CA
  5. aandpman
    aandpman 1/2 ton status Premium Member
    Sep 6, 2001
    151
    7
    Austin, Texas
    Unless your 15" wheels happen to be stock steel rallye wheels, in which case a 14Bff hub will not fit thru the middle without having the hubs turned down some.
  6. K5Kell
    K5Kell Guest
    I just swapped in a 14blt FF and I bought wagon wheel 15 inch rims and they fit fine, I think the backspacing was 4.25, dont hold me to that number though /forums/images/graemlins/confused.gif.
    -Kell-
  7. WARP1
    WARP1 Registered Member
    Apr 8, 2000
    63
    Omaha, Nebraska
    I did the swap with 15" steel wheels. They fit the 14bolt rear fine, but they won't clear the 8 lug front with out grinding the brake caliper. I ended up switching to 16" wheels.
  8. MudFrog
    MudFrog 1/2 ton status
    Feb 23, 2000
    3,236
    Daleville, Va
    15" wheels will fit over the drums. If you do a disc brake swap then you would need to grind.
