14 bolt axle tube diameter?
Discussion in 'The Garage' started by ryan22re, Oct 28, 2005.
  1. ryan22re
    ryan22re 1/2 ton status
    Feb 5, 2005
    3,368
    Irmo, SC
    whats the diameter of a 14 bolt full floater? i measure mine at 3.5 inches. going to get some u-bolts made today.
    ryan
  2. thatK30guy
    Jan 12, 2001
    32,076
    55
    3 3/8" is the true measurement.
  3. ryan22re
    Feb 5, 2005
    3,368
    Irmo, SC
    hmm....so you think thats what i should tell that to the spring shop making my u bolts? or is 3 1/2 close enough?
    ryan
  4. ryan22re
    Feb 5, 2005
    3,368
    Irmo, SC
    nevermind, ill just take my spring plates....
    thanks for the response.
    ryan
  5. txfiremank5
    txfiremank5 1/2 ton status
    Jul 6, 2004
    3,105
    San Antonio, TX.
    3 3/8" for mine too... mines from an 89 V3500 SRW.
  6. thatK30guy
    Jan 12, 2001
    32,076
    55
    If you go 3.5", you will probably struggle with pulling the threaded ends of the u-bolts apart to try to get them to line up in the plate holes.
    You gotta trust me (and many, many others on this one), it really is 3 3/8" o.d. tubes on the 14FF. Get a caliper and measure it. Thats how I found out a loooooooong time ago. :waytogo:
  7. mikey_d05
    mikey_d05 1 ton status GMOTM Winner
    Nov 23, 2004
    10,453
    Minnesota
    Yeah, it's 3 3/8", I still have the 3.5" pair of u-bolts I had made sitting around somewhere.
  8. 6.2Blazer
    6.2Blazer 1/2 ton status
    Feb 24, 2000
    4,675
    26
    Ohio
    I agree, it's 3 3/8"............however a 3 1/2" u-bolt works fine. Several aftermarket lift companies and a couple of the local spring shops I've talked to don't even offer the 3 3/8" size u-bolts. I used 3 1/2" u-bolts for years with 4" blocks and 38" tires, and a different set with shackle flip (no block) and have never had problems with them on the trail.
  9. ryan22re
    Feb 5, 2005
    3,368
    Irmo, SC
    just had them made.
    3 and 3/8
    took my spring plates with me.
    i love my spring shop.
    ryan
