14 bolt axle
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by RustBuket, Feb 26, 2003.
  1. RustBuket
    RustBuket 1/2 ton status
    Feb 21, 2003
    1,618
    Saskatchewan, Canada
    What trucks did they come on? Where should I start to look? Any tips? Thanks.
  2. 88sub4x4
    88sub4x4 1/2 ton status
    Sep 22, 2002
    792
    Long Island, NY
    14 bolt semi floaters came on 3/4 ton trucks. 2WD had 6 lugs, and 4WD had 8 lugs. The 14 bolt full floater came on some 3/4 ton 8 lug 4x4 and 1 ton 2WD and 4WD trucks. Every big block, and/or diesel 3/4 ton I have seen has the Full floater. The small block 3/4 tons usually have the semi floater, but the full floater may have been an option on them. I have also seen a 14 bolt semi floater 5 lug, but this was under the 1/2 ton 2WD 88 and up pickups, and 92 and up subs and blazers with the 454 SS package. Not a very common thing though. This is what I have come across anyway. Maybe someone can verify this. /forums/images/graemlins/burb.gif
  3. BamBamblazer
    BamBamblazer 1/2 ton status
    Jun 24, 2002
    486
    McCordsville, Indiana
    What year's did the 14 sf come in? I am most interested in the 6 lug version. Any help is great.
  4. heavy4x4
    heavy4x4 1/2 ton status
    Aug 28, 2002
    3,270
    Delafield, Wisconsin
    Well, not to be an ass, but the best place to start is the "search" button at the top of the page. /forums/images/graemlins/deal.gif
    But, as said above - you can find 14 bolt FF and 14 bolt Semi-floaters in various makes and models. Sometimes I wonder if GM had a system to the placement of what axle under this truck, and what axle under the next. If getting a FF from a 3/4 ton 4x4 truck, it will bolt up DIRECTLY to your application. One from a 3/4 ton 2wd will bolt up too, but the shock locations are 2 inches further downward - so they'll have to be moved or longer shocks installed. The 14 bolts from a one ton will work, but the spring perches need to be cut off and re-welded further out. 1 inch on each side out to be exact. Hope that helps, and like I said, do a search - you'll be sure to find answers.
  5. afroman006
    afroman006 1/2 ton status
    Aug 21, 2002
    2,876
    Not true. My old truck is a 3/4 ton 2WD and has an 8 lug semi floater.
  6. Beast388
    Beast388 1/2 ton status
    Nov 6, 2001
    3,039
    Clinton, IA USA
    Correct.....every once in a while I'll see a Z71(6 lug) with the 14 bolt semi-floater axle. The 14bsf was/is available in 1/2 & 3/4 ton trucks...2 or 4 wheel drive. /forums/images/graemlins/thumb.gif
  7. u2slow
    u2slow 1/2 ton status
    May 9, 2001
    2,217
    BC Canada
    6-lug 14-bolt (9.5") applications:
    88-98 K1500 w/F44 option
    88-98 K2500 w/6-lug wheels (same width as K1500)
    88-98 C2500 w/6-lug wheels (narrower than K-series)
    96-up Savana/Express 2500 w/6-lug wheels (widest of the bunch)
    Possibly others, but my expertise doesn't extend into the newer Silverado trucks.
  8. ZonkRat
    ZonkRat 1/2 ton status
    Jan 16, 2003
    1,003
    Lawrence County Tennessee
    My brotherinlaws got 6 lug version under 86 4x4. /forums/images/graemlins/thumb.gif
  9. 88sub4x4
    Sep 22, 2002
    792
    Long Island, NY
    Well, there goes my theory of axle finding logic out the window. I just worked on a 8 lug 2WD 3/4 ton with a 14 SF so I have proved myself wrong as well. Looks as if the best way to find an axle, is to go to the yard and look under every chevy truck till you find the one you want. Sounds like lots of fun /forums/images/graemlins/grin.gif /forums/images/graemlins/burb.gif
