14 bolt bigger than the standard 14bolt?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by MudFrog, May 8, 2001.
  1. MudFrog
    MudFrog 1/2 ton status
    Feb 23, 2000
    3,236
    Daleville, Va
    There is a 14 FF on ebay for sale. I doubt I'll bid on it but it struck me curious.. the dude said it's out from under a camper and the pumpkin is bigger than the standard 14 bolt axle. Do you think he's referring to a FF compared to a SF? Thats the only thing I can think of.
    http://mudfrog.coloradok5.com
  2. 2Dogs
    May 4, 2001
    3,470
    35
    Ca
    If it is, he is not too smart for missing the FF sale value.
    Buying rear-ends over the net.....Ha
  3. Twiz
    Twiz 1/2 ton status
    Mar 8, 2001
    3,729
    Clearfield Ut.
    If you strickly count the bolts. There are 2 "14-bolts". (That I know of, but have been proven wrong before)
    1- 14 bolt full floater; Big-pig, yery big. 10.5 ring gear. Pinoin nose is suported by a "neadle" type bearing that is a yery strong set up. Center casting useualy- but not allways- have allot of strengthining ribs bilt in, but the silouette would be about the same. Bolt on pinion bearing support. Full-floater. 2 diferent brake options 13" X 2.5" and 13" X 3" (I THINK)
    2- 14-bolt semi-floater: Seams like it is a smaller center section (but I'm not sure) 9.5" ring gear. Standerd ring and pinion set (no bolt on pinion bearing suport, no 3rd bearing on the nose of the pinion). Bum cover uses sealent and not a gasket. Not a full floater. Can be a 6 or 8 lug. Big, big shafts. Can be found on 1/2 tons (Newer models, w/some kind of tow package, very rare, I've only seen one on a 1/2 ton), The bum cover looks yery different than it's bigger brother.
    By the way. 14-bolt is a slang term. Parts guys that know numbers, know the difference between a 9.5" gear and a 10.5" gear. But SOME of them do not know or care what a 14 bolt is. It's all about P/N (part numbers) not bolts.
    Twiztid,
  4. xtreme_wlr
    xtreme_wlr 1/2 ton status
    Mar 22, 2001
    103
    San Diego, CA
    It sounds like the guy doesnt know what he has. I would bet that it is a dana70.
    '78 Chevy 1 ton Stepside RockCrawler
    468 BB, SM465, NP205
    D60 front, GM 14Bolt rear w/ Detroit
    <A target="_blank" HREF=http://65.11.18.114>http://65.11.18.114</A>
  5. Blazer1970
    Blazer1970 1/2 ton status
    1,600
    Old Mission, MI
    Don't know what axle that guy has for sale, but there is a bigger 14 bolt. My 2001 2500HD has the new 11.5" 14 bolt full floater. This is obviously not what he has for sale, but it does exist (MY2001 only).
    Tim
    70 Blazer CST 4X4 350 SM465 NP205
    87 Burb 4X4 350
    01 GMC 2500HD 4X4 Duramax/Allison
