14 bolt bolt up?
Discussion in 'The Garage' started by nicotine, Jan 15, 2004.
  1. nicotine
    nicotine 1/2 ton status
    Jan 11, 2004
    116
    this is probbly a stupid question but a buddy of mine can get a smoking deal a 14 bolt ff but it is out of a 70's chevy van and has some wiered gear ratio like 3:27 i think. the question is will this 14 bolt replace his 10 and just bolt right up? /forums/images/graemlins/ears.gif
  2. big83chevy4x4
    big83chevy4x4 3/4 ton status
    Mar 22, 2002
    6,587
    Sheridan, Michigan
    out of a van, no. he will need to grind off the old ones and weld new ones on. the van is more desirable because it is very close, if not the same width as the front. he will also need a different pinion yoke or a conversion ujoint for the drive shaft to bolt up. you will also need to regear it to match the front.
  3. nicotine
    Jan 11, 2004
    116
    grind off the old what?
  4. mechted
    mechted 1 ton status Premium Member
    Oct 19, 2003
    767
    Granbury, TX
    spring perches, and maybe shock mounts
  5. big83chevy4x4
    Mar 22, 2002
    6,587
    Sheridan, Michigan
    sorry my mind was thinking faster than i can type. /forums/images/graemlins/eek.gif
    he will have to grind off the old spring perches.
  6. nicotine
    Jan 11, 2004
    116
    what would he have to replace in thier place or what angle?
  7. big83chevy4x4
    Mar 22, 2002
    6,587
    Sheridan, Michigan
    there are a couple of people on here that make the spring perches. it would be best to mock up the suspention and point the pinion directly at the t case output and tack them in place then take the axle out and weld them in. or he could just weld them in at the same angle as the old ones and just use shims
  8. kennyw
    kennyw N9PHW Premium Member
    Jun 9, 2002
    13,224
    94
    Stevens Pass Highway, WA
    He would only need to point the pinion at the Tcase if he is running a CV style rear driveshaft. If he is running the stock drive line welding them in the same angle he cut them off from would be correct.
  9. R72K5
    R72K5 Banned
    Mar 5, 2001
    8,905
    central IL
    should be 3:21 if it is 3:20-anything, weld the perches to the van axle the same way that they are welded to your original axle under your rig now so that it points the same way, unless your truck is really super lifted in which then you would want to tip the pinion of the axle up a little more
    3:27 ratio wa sin the borg warner 9 bolt axles in the third gen camaros and firebirds, those axles not available until 85-up, some ppl like to call them the australian axle
