14 bolt brake lines!!
Discussion in 'The Garage' started by George_Pimpdaddy, Apr 26, 2007.
  1. George_Pimpdaddy
    George_Pimpdaddy 1/2 ton status
    Oct 17, 2002
    1,306
    Edmonton Alberta Canada
    K into the swap from my 10 bolts to the 14ff so its short the lines like only a inches sticking out of the backing plate someone cut em off :doah:
    Anyways whats my options here on getting them hooked up like should i make new lines with a bender and fittings or should i look at the delership for a set? any part numbers? that would be sweet.
    also could i reuse my brake lines on my 10 bolt and hook em up on the 14?
    anyways thanks guys just figured id ask here since u guys are my tech database :bow:
    89 :k5: 355/700/241
    10 bolts 35" BFG Mud's
  2. Jason4x4
    Jason4x4 1/2 ton status
    Nov 5, 2006
    4,505
    6
    Chandler, AZ
    use the ones from the 10 bolt if they fit.
  3. Russell
    Russell LB7 Tahoe Status Premium Member GMOTM Winner
    Jun 23, 2000
    7,925
    337
    Fort McMurray, Alberta
    I have a set of good 14 bolt brake lines -- PM me if you want them, I'll be in the city tommorow at the building you met me at last time :)
  4. MattK
    MattK 1/2 ton status
    Jan 12, 2005
    1,713
    Dallas, TX
    They should fit. Even if they dont, it's only a few bucks to make your own.
  5. Mudstud
    Mudstud 1/2 ton status
    May 29, 2001
    1,472
    Memphis, TN
    You can buy different lengths of brakeline at the parts store with the flared ends and fittings on it. Just measure how much you need and tell them- Should be 1/4 brake line but don't know right off what fittings the are.
  6. George_Pimpdaddy
    Oct 17, 2002
    1,306
    thanks guys i already got the 10 bolt dropped so ill try the 10 bolt brke lines since they look to be in great shape.
    Sierrra Classic - if you would want to let go of those brake lines id be willing to work something out even jsut for them being dropped off if u could, id be more than happy to use em only problem is that i have no wheels right now so ud have to stop by my house, its right by bonnie doon and whyte ave bout 87st. thanks dudes
