14 bolt brakes
Discussion in 'The Garage' started by surpip, Jul 13, 2004.
  1. surpip
    surpip 1 ton status
    Apr 7, 2004
    10,877
    sacramento ca
    /forums/images/graemlins/1zhelp.gifone of the last things i need to find for the one ton swap is the dist. block for the rear brakes. is there a p/n for this or is it somthing i need to get from a junk yard? im talking about the little block that sits in the center of the axle that connects the center drop down line to the 2 lines coming from the brakes. /forums/images/graemlins/1zhelp.gif thanks,
    dale
  2. cybrfire
    Dec 15, 2002
    15,142
    568
    Iowa
    That t block or distribution block as you refer to it is part of the flexible line that drops from the frame to the axle. Anybody that sells extended brake lines can hook you up with what you need.
  3. surpip
    surpip 1 ton status
    Apr 7, 2004
    10,877
    sacramento ca
    so the extended brakelines i bought from ord should have the "t" block allready on it?
  4. spearchucker
    spearchucker 1/2 ton status
    Nov 17, 2003
    1,556
    Bay area, CA
  5. surpip
    surpip 1 ton status
    Apr 7, 2004
    10,877
    sacramento ca
    right on dumbass me diddent evan look at the line when i got it
