14 BOLT BRAKES?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by mudddog91, Jul 22, 2001.
  1. mudddog91
    mudddog91 1/2 ton status
    Dec 28, 2000
    471
    north carolina
    hEY GUYS ANYONE HAVE A PROBLEM WITH THE DRUM BRAKE WHEEL CYLINDERS ON THE 14 BOLT FF?iVE REBUILT MY WHEEL CYLINDERS AND FOR SOME REASON THE DRIVERS SIDE PISTON AND SEAL POPS OUT PUKING BRAKE FLUID EVERY WHERE!!!!!!!!Also can someone point me to the area of the proportioning valve that is supposed to be pushed in to bleed the rear brakes?It calls to do this when ever you bleed the rear brakes,has to do with the safety valve that allows only front or rear systems to work if one or the other fails??????
  2. rock.monkey
    rock.monkey 1/2 ton status
    Oct 28, 2000
    296
    100 Mile house B.C. Canada
    buy new wheel cylinders.
    Bill Innes
    88' Jimmy
    Built for <font color=blue>Function</font color=blue> <font color=red>NOT</font color=red> <font color=blue>Fashion</font color=blue>
  3. Triaged
    Triaged 1/2 ton status
    Feb 21, 2001
    3,808
    CA (LA/OC area)
    If the seal is popping out of the cylinder you have probs. with something in how the shoes are set up. From the factory you can wear away all of the friction material and half of the metal before the seal would even think of comming out. My guess would be: wrong shoes, wrong link pins (that go from the wheel cylinder to the shoe) or star wheel, or being searously out of adjustment.
    '71 Blazer CST w/ a 400sbc, 4" lift, 36" Supper Swampers, and alot of rust
  4. woody9
    woody9 1/2 ton status
    May 27, 2001
    602
    Howell, MI
    I'm with the earlier post. Just go with 'new' cyl's! With the warranty on 'em.... less time messing with rebuild they're worth it!
    Do it once, and do it right!
