14 bolt but not FF. Disk Conversiom
Discussion in 'The Garage' started by capps, Dec 15, 2004.
  1. capps
    capps Registered Member
    Feb 6, 2004
    40
    Atlanta (Snellville)
    I have searched and found quite a bit of posts for the 14 bolt full floater rear disk brake conversions, but my Suburban did not have the full floater axle. Are there kits for this application also? Has anyone performed this?
  2. Emmettology 101
    May 9, 2000
    8,126
    FL
    PM Blue85, he has done a disc conversion on a 14SF.. :D
  3. smokkey1
    smokkey1 1/2 ton status
    Jan 7, 2004
    2,677
    Los Angeles, CA
  4. capps
    Feb 6, 2004
    40
    Is TSM the only rear disk brake kit for the semi floater 14 bolt rear end? I searched and found several for the full floater.
  5. capps
    Feb 6, 2004
    40
    I guess TSM is the only company making the rear disk brake conversion for the SF 14 Bolt rear. I have a full floater also, but the shock mounts are opposite of the 84 Suburban. I did not want to open up another can of worms by swapping axles also.
  6. muddog
    muddog 1/2 ton status
    Jan 23, 2003
    262
    Cadmus, KS
    IF you can get me some specs I can get them cut for you. Or I already have 25 sets cut for the 14FF. pm me if you are interested in either
  7. Pookster
    Pookster 1/2 ton status
    Nov 21, 2000
    3,195
    NYC, NY, USA
    I'd take two. :xmas:
  8. muddog
    Jan 23, 2003
    262
    Cadmus, KS
    If you can get me some specs I can get them cut for the 14sf. Also, what spacers would you prefer? Solid or tube(actualy I use 1" round tube and cut a .5" hole so it is thicker than tubing) obviously tube is cheaper than solid. 6 lug or 8 lug?
