14 BOLT carrier bearings
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by 76K5, Mar 13, 2003.
  1. 76K5
    76K5 Registered Member
    Jun 23, 2001
    99
    North Carolina
    My buddy's 14 bolt bearings are screwed. If we install new ones will we have to reset the backlash or not? Thanks for the help. /forums/images/graemlins/usaflag.gif /forums/images/graemlins/usaflag.gif /forums/images/graemlins/usaflag.gif
  2. Shaggy
    Shaggy 3/4 ton status
    Dec 15, 2000
    6,737
    Los Banos, CA
    <font color="green"> Yes you will, but it's real easy on a 14 bolt. </font>
  3. K5MONSTERCHEV
    K5MONSTERCHEV 1/2 ton status
    Jan 27, 2003
    3,254
    Castro Valley, CA
    Do a pattern check and check what the backlash is before you tear it apart.
  4. Blazer79
    Blazer79 1/2 ton status
    1,816
    Guatemala, Central America
    The answer to your question is no. All you have to do is mark properly where the adjusting screws (large with holes all around them) were before you start, and after replacing the bearings, move them back to their original position (exact number of turns). Then torque the bearing caps to spec and thats it.
    This article will help you: Detroit Locker Install It's very easy once youre doing it.
    Edit: I'm talking about the two bearings on the sides of the carrier only. If you need to replace the pinion bearings, then yes, you have to set everything from the beginning.
  5. Shaggy
    Dec 15, 2000
    6,737
    Los Banos, CA
    <font color="green"> I think that it's a good idea to check the backlash when you replace the bearings. You never know what might happen, and it only takes a few minutes to check it. </font>
  6. Mudstud
    Mudstud 1/2 ton status
    May 29, 2001
    1,472
    Memphis, TN
    Is that is what a dial indicator is for? Any trick to measuring it if you don't have a dial?
  7. Shaggy
    Dec 15, 2000
    6,737
    Los Banos, CA
    <font color="green"> Yes, the trick is to buy a dial indicator or find someone that has one you can borrow. /forums/images/graemlins/rolleyes.gif/forums/images/graemlins/thumb.gif </font>
  8. K5MONSTERCHEV
    Jan 27, 2003
    3,254
    Castro Valley, CA
    The reason to check the backlash it so that you know what its at so when you put it back together you know where to run it.
  9. CrazyCoot
    CrazyCoot Registered Member
    Nov 24, 2002
    25
    Redding, CA
    A dial indicator is almost worthless when dealing with a used set of gears. The factory specs. are of no use on used gears. If there is no side to side play in the carrier, you could measure it first, then set the same when you put it back. I always check pattern before disassembly and set backlash for the best pattern durring assembly.
  10. K5MONSTERCHEV
    Jan 27, 2003
    3,254
    Castro Valley, CA
    The backlash openes up a little bit when the gears get used. The backlash only changes the pattern verv minimal, the pinion depth is what changes the pattern.
  11. CrazyCoot
    Nov 24, 2002
    25
    Redding, CA
    You would be amazed at how much backlash changes the pattern on a used set of gears.
  12. K5MONSTERCHEV
    Jan 27, 2003
    3,254
    Castro Valley, CA
    Well from my experioce it doesnt change the pattern very much, a few thou is nothing. I suppose it all depends on how much its changed.
