14 bolt carrier break?
Discussion in 'The Garage' started by richheezee, Oct 6, 2005.
  1. richheezee
    richheezee 1/2 ton status
    Dec 29, 2003
    116
    San Jose CA
    i have had a 14 bolt sitting in my yard for a while and i am close to installing it. i felt lucky that the spring pads were correct width but i was under the impression that it had a 4:10 or 4:56 ratio. i open the diff and check the numbers on the ring and the last few are 14 45 10 86. does that mean it's a 3:21 made in oct. 86? i never heard of 3:21. what options do i have to regear? is there a carrier break? what do i do? :confused:
  2. sandawgk5
    sandawgk5 3/4 ton status
    Oct 28, 2003
    6,881
    Kitsap County PACNORWEST
    If your numbers are correct your math is right. The carrier break is 4.10 and down and 4.56 and up. So if you do have 2.32 or what ever you can go as high as you want because they sell "thick" gear sets in 4.56 and up so they will fit on the 4.10 and down carriers.
    Ira
  3. richheezee
    Dec 29, 2003
    116
    San Jose CA
    can i just swap in a new 14 bolt carrier with 4:10's or 4:56's and be done with it? i think the answer is yes but i just want clarity. my jimmy is diesel with a 700r4 and i am running 35's. so i think i would be comfortable with either. thanks.
  4. monster man
    monster man 1/2 ton status
    Oct 20, 2003
    282
    Reno, NV
    which is better for strength- thick gears on a small carrier, or the thicker carrier for 4.56 and numerically up? I'm trying to decide what to do myself. Can the front Dana 44/10 bolt also add "thick" gears in, say, 4.56 so you don't have to change the carrier up front as well?
    the easiset way to tell what ratio you have is to mark a line at 12 on your brake drum or whatever you have left on the axle, turn it two full revoltuions back to 12 and watch how many time the driveshaft yoke spins fully around. It should spin 3 1/4 turns if you have 3.21's
  5. sandawgk5
    Oct 28, 2003
    6,881
    You would also have to change the pinion of course. But there is no reason to get a new carrier yours will fit any gear ratio. Find a used set of gears cheap and swap them out. No matter what you do you will have to "set them up". I think I might not have answered your question.
    Ira
  6. richheezee
    Dec 29, 2003
    116
    San Jose CA
    oh yah, i forgot to add that about the pinion as well. :o thanks for your help. i appreciate it. any body giving away a free 4:10 ring and pinion? j/k maybe. lol
  7. sandawgk5
    Oct 28, 2003
    6,881
    Nope I Have a set of 3.73 that I took out of mine. I got my 4.10s for 50 bucks from a guy on here and still do not have them installed :doah: .
    Ira
  8. 79chevyk10
    79chevyk10 1/2 ton status
    Dec 14, 2003
    612
    Central Coast
    Not sure about a front 10 bolt, but I know for sure the no thick gears are available for the D44, must repl. carrier, but they are on 45 to 50 bucks, not to bad.
  9. sweetk30
    Nov 1, 2004
    25,554
    548
    horseheads , ny 14845
  10. richheezee
    Dec 29, 2003
    116
    San Jose CA
  11. k204dr
    k204dr 1/2 ton status
    Aug 27, 2004
    463
    TN
    No thick gears for a d44? ever heard of a jeep rubicon? they have 4.10 gears stock that fit on a older d44 3.73 carrier. I know this for a fact cause i have them front and rear in my scout.
  12. pauly383
    Jul 22, 2001
    16,217
    Mesa , Arizona USA
    Try dividing 45 by 10 :D
    But I am not sure on full floaters .
  13. sweetk30
    Nov 1, 2004
    25,554
    548
  14. SUBFAN
    SUBFAN 1/2 ton status
    Mar 23, 2003
    2,334
    Davenport, Ia
    What are the chances of pulling the whole R&P, carrier, and the pinion 'housing' and sliding it into another axle and having it all work right?
    Is there enough adjustability built in to tweak it without doing the whole nine yards?
  15. skelly1
    skelly1 1/2 ton status
    Sep 2, 2002
    554
    San Diego, CA
    I got 2 14BFF axles with 3:73's, if you're interested, email me at steve_kelly1@yahoo.com. My wife would love to see them gone (cheap).
  16. SUBFAN
    Mar 23, 2003
    2,334
    Davenport, Ia
    Thanks, but I to am the proud owner of a pair of 3.73 geared 14FF's.
    I think I found 4.56's though :D .
