14 bolt conversion Q's
Discussion in 'The Garage' started by smprider112, Jul 6, 2004.
  1. smprider112
    smprider112 1/2 ton status
    May 1, 2004
    624
    Beaverton,Oregon
    14 bolt conversion Q\'s
    OK, gonna try to aquire the parts I need to get my 14 bolt under my truck...I still need to get the perches welded on, but untill then I might as well get everything else squared away.
    -Ok so whats the conversion U-joint number I need?
    -Where can I find larger U-bolts (4inch lift block)?
    -Can I use the E-brake lines that are on the 14b (out of a van if that matters) or should I reuse my 10 bolt ones? just from a quick look under it they look like they attach differently (The van ones)
    -Can I reuse my brake line off my stock 10 bolt?(the rubber line that connects to the steel one) cuz I had to cut the van one off.
    -And finally does anyone know if the Van spring perches are the correct angle for use in a truck? I know the perches are to far out, but Im just gonna have the new perches welded on and leave the old ones too (plenty of room) and I figured it would be easier to match the stock angle (If I can) or are the van ones different for some reason??
  2. 86chevybanshee
    86chevybanshee 1/2 ton status
    May 15, 2004
    917
    beverly MA
    Re: 14 bolt conversion Q\'s
    u joint number is 447 from napa
  3. backyardbuilt
    backyardbuilt 1/2 ton status
    May 28, 2002
    1,301
    Olathe, Kansas
    For U-bolts any spring shop can make them for you for around 45$
    Not sure about the van e-brake cables.
    Yes you can use the stock brakeline from the 10 bolt.
    Since the blocks have the angle milled into them for the lift you can attach the new perches exactly the same as the old ones.
  4. ugly_blazer
    ugly_blazer 1/2 ton status
    Apr 12, 2004
    1,214
    When the spring perches are welded on you should have them welded to give you the pinion angle that you need.
  5. POWERMAD
    POWERMAD 1/2 ton status
    Mar 4, 2001
    3,466
    Oregon
    Oregon Spring on Stark makes u-bolts.
  6. smprider112
    May 1, 2004
    624
    Beaverton,Oregon
    also forgot, is there somewhere I can get the proper spring plates for a 14bolt? the ones that I took off the van arent wide enough for my springs.
  7. backyardbuilt
    May 28, 2002
    1,301
    Olathe, Kansas
    Muddytazz on here makes some good ones.
  8. POWERMAD
    Mar 4, 2001
    3,466
    Oregon
    They might have them, if not try 4wheel parts on 82nd.
    Beal or 6 States off of Columbia may have them too.
  9. POWERMAD
    Mar 4, 2001
    3,466
    Oregon
    /forums/images/graemlins/doah.gif... Jeff's local too. /forums/images/graemlins/deal.gif
