14 bolt conversion
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by chaka454, Mar 18, 2002.
  1. chaka454
    chaka454 1/2 ton status
    Nov 13, 2001
    199
    California
    The question is do I need bigger u-joints for the 14 bolt? do I need to shorten my drive shaft? what else do I have to do to make the 14 bolt fit, cut and weld something? if I need bigger u-joints does anybody have the part # they've used? sorry for all the questions.
  2. Hossbaby50
    Hossbaby50 3/4 ton status
    Sep 1, 2001
    8,972
    Peoria, AZ
    The hybrid ujoint you will need is Napa #447. All the rest of the info you can find threw a search of old posts. This comes up alot.
  3. chaka454
    Nov 13, 2001
    199
    California
    Ok thanks alot.
  4. woody9
    woody9 1/2 ton status
    May 27, 2001
    602
    Howell, MI
    used the u-joint mentioned on my 91 350/700R4 Suburban when i put a 14FF in. It did take different axle/spring U-Bolts however.
    Also gained from 3:42-15" to 4:10-16" on my swap but it send speedo +20%. Kit from GM to fix it for about $30 (haven't done it yet cause you need to pull speedo/gauges and haven't had any other cause to open her up!).
  5. ChevBlazin
    ChevBlazin 1/2 ton status
    Feb 4, 2002
    332
    St. Paul area, Minnesota
    do you happen to know what part # hybrid u-joint is needed to go from a 10 bolt t0 12 bolt?
  6. 87GMC
    87GMC 1/2 ton status
    Nov 5, 2001
    653
    Olathe, KS 66061
    NAPA #348
  7. 4GUNZ4X4Z
    4GUNZ4X4Z 1/2 ton status
    Aug 10, 2000
    3,459
    Mustang, Oklahoma
    I just did this 2days ago on my K5 the only parts I had to buy was the u-joint and brake fluid. I would buy a 447 and a 348, then take back the one you dont need. The 447 was twice the price of the 348. The 447 on the 1ton side is about a 16th of an inch smaller on the cap then the 348. And the 447 is longer on the 1/2ton side then the 348. I'm running 74'k5 driveshaft w/boyce 14bolt.
