14 bolt corp fitment
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by blazd88, Apr 26, 2004.
  1. blazd88
    blazd88 1/2 ton status
    Mar 16, 2004
    1,055
    Lubbock, Tx
    i have found a 1 ton 14 rear but it is a dually. i was wondering how much i would have to change to make it single wheel and what else would be involed in putting under my K5 /forums/images/graemlins/dunno.gif
  2. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    If it's a 14 bolt from a dually pickup I'd verify the width because if it's from a cab and chassis truck it isn't even gonna be close.
    What did it come from?
  3. blazd88
    Mar 16, 2004
    1,055
    Lubbock, Tx
    not sure because all it is is a frame but ill measure and get back to you
  4. padrik5
    padrik5 Bike repair man
    Mar 13, 2004
    37
    Bremerton Wa
    do u know a guy named luise
  5. miniwally
    miniwally 1/2 ton status Premium Member
    Aug 11, 2003
    3,065
    Colorado
    You can make a dually front or rear end a single wheel front or rear end by using the single wheel hubs and rotors on the front or the single wheel hubs and drums on the rear. When switching from a dually to single wheel on the rear I think it works out better and easier to put disks on instead of the drums. The axle housings are almost exactly the same only two differences that I know of: 1 spring perch width on all 1 tons was different that 1/2 and 3/4 tons. 2 I think that the break backing plates are in different locations fro dually to single wheel.
    The fronts are real easy. The rears do require quite a bit of work to make them mount to any thing but a 1 ton frame.
  6. blazd88
    Mar 16, 2004
    1,055
    Lubbock, Tx
    not that i know of why
