14 bolt crush sleeve
Discussion in 'The Garage' started by johnathan, Oct 22, 2005.
  1. johnathan
    johnathan 1/2 ton status
    Sep 26, 2005
    376
    Ocean Springs,MS
    my question is where does the crush sleeve go,,,in between the bearings,,,or in between theyoke and the top bearing
  2. johnathan
    Sep 26, 2005
    376
    Ocean Springs,MS
    another question do I press the top bearing on the shaft with the yoke
  3. dave_90_blazer
    dave_90_blazer 1/2 ton status
    Jan 1, 2004
    688
    Melvindale, Michigan
  4. dave_90_blazer
    Jan 1, 2004
    688
    shouldn't need to "Press" in on, but it is ok to use the yoke to push it in the needed amount
  5. K5MONSTERCHEV
    K5MONSTERCHEV 1/2 ton status
    Jan 27, 2003
    3,254
    Castro Valley, CA
    Tap the outer bearing on with a hammer or something, but dont mess up the splines on the pinion. Have fun crushing the sleeve. We use a press at work. Maybe you can take it to a local shop and theyll set it all up for you.
  6. BigCountryx
    BigCountryx 1/2 ton status
    Feb 19, 2005
    519
    Gonzales, LA
    I used a 3/4" drive impact to crush it. Had a guy tell me that they (his shop) don't use crush sleeves. They cut tubing to use as a spacer, just a hair shorter than the used sleeve and shim to get the proper preload. Said they do this esp. in their drag race applications. Anybody ever hear of this?
  7. dave_90_blazer
    Jan 1, 2004
    688
    never heard of using tubing, but that is called a solid spacer sleeve
  8. u2slow
    u2slow 1/2 ton status
    May 9, 2001
    2,217
    BC Canada
    There's kits like this for a Ford 9" and others. Makes sense to use where you might be changing ratios often.
  9. johnathan
    Sep 26, 2005
    376
    Ocean Springs,MS
    Appreciate the help.Iwas sure the the sleeve had to go between the bearings ,only way that makes since,my dad on the other hand did'nt so I'd a
    sk someone who's sure to know.Yeah that sleeve is a pain in the a@#.Did'nt have the right tools so we went through five half inch pull handles and two rachets.It's all together with that fresh detroit.Man what a DAY! :D
