14 bolt/Detroit locker question
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by blazbrnc, Jun 1, 2001.
  1. blazbrnc
    blazbrnc 1/2 ton status
    Mar 16, 2001
    181
    southern MI
    I just acquired two 14 bolts, both out of mid-seventies 3/4 tons. Was a Detroit locker ever available from the factory? I don't think either one of these was ever opened up and when I pulled the cover on both of them I saw something that looks very different from any open 12 bolt rearend I have seen. I know what a gov-loc looks like and that isn't what it is. I'm thinking that they are both open but I can just barely see one spider gear through a hole in the plate that the ring gear bolts to. On the pinion side of the ring gear it just looks like a spool with strengthening ribs. Is this just what a FF open carrier looks like? Thanks
  2. tRustyK5
    Jul 23, 2000
    36,173
    1,385
    E-town baby!
    Yes, the carrier itself actually splits in half and if you split it you'll see a cross with 4 spiders on it...if its open.
    Rene
    <font color=red>If at first you don't succeed...skydiving ain't for you!</font color=red>
  3. HarryH3
    HarryH3 1 ton status Author
    May 31, 2000
    10,384
    Georgetown, TX
    Sounds like an open carrier to me. It's a pretty beefy hunk of steel. The only 14-bolt FF's that I know of that came with Detroit Lockers were those installed under some military vehicles. Also, there are no spider gears after the installation of a Detroit Locker, if you can see a spider gear than it doesn't have a Detroit Locker installed.
    Rotate the carrer and count how many pinion shafts there are for the spider gears. The open diff had 4 spider gears, while the Gov-Loc had only 3.
    You can see a picture of the insides of a 14-bolt FF at <A target="_blank" HREF=http://www.coloradok5.com/gearinstall.shtml>http://www.coloradok5.com/gearinstall.shtml</A>. From the picture, you can't even tell that there's a Detroit Locker in that diff. It installs inside the factory open diff, replacing the stock spider and side gears.
  4. pcorssmit
    pcorssmit 1/2 ton status
    Jan 2, 2001
    1,346
    Denver, CO
    Not all 14 Bolt FFs had 4 pin carriers, some had 2 or 3. You must have the 4 pin carrier to install a Detroit. They have 4 spider gears in a circle, for a total of 6 spider gears.
    Pete
    '83 K5, 350 TBI (ex 6.2), 700R4, NP208, Dana 60/14 bolt, 4.56s, Detroits, 3" lift, 15-39.5x15 TSLs
    '97 Dodge 2500 4x4 CC LB Sport, Cummins 5 spd
  5. HarryH3
    May 31, 2000
    10,384
    Georgetown, TX
    Hi Pete, I've never seen a 2-spider 14 bolt FF. Sounds rather weak. I know that the Gov-Loc's used the wierd 3-spider set up. All the open ones I've ever seen had 4 spider gears. When you say there's a total of 6 spider gears, are you counting the side gears as spider gears? Mine had 4 spider gears and 2 side gears. All got replaced by Detroit Locker parts.
    And indeed, the Detroit Locker will only fit in the 4-pinion, open carrier. PowerTrax has a locker available for the Gov-Loc cases now, but I'd much rather have the Detroit Locker for its legendary ability to take abuse. [​IMG]
  6. mudddog91
    mudddog91 1/2 ton status
    Dec 28, 2000
    471
    north carolina
    Ive got a 14 boltff in my 74 3/4 ton.i havent been inside it yet but it sure does bark going around corners.I was wondering if it is the gov-loc or what?is the gov-loc good or do i need to ditch it and find an open carrier to install detroit?
