14 bolt disc brackets from DIY4x
Discussion in 'The Garage' started by iwaxmyjimmy, Feb 2, 2007.
  1. iwaxmyjimmy
    iwaxmyjimmy College web wheeler Premium Member
    Nov 3, 2006
    2,802
    34
    Greenville NC
    what rotors do these brackets use?
  2. 4X4HIGH
    Dec 14, 2001
    22,060
    69
    Pleasanton, CA.
    Pretty sure his brackets use the same rotors as everyone elses brackets which are 73-87 truck (91 burb) front 3/4 ton rotors.
  3. iwaxmyjimmy
    Nov 3, 2006
    2,802
    34
    Greenville NC
    Oh, I'm putting together my "to do list" of stuff I need to get done to my truck before spring break rolls around.
  4. cybrfire
    Dec 15, 2002
    15,139
    565
    Iowa
    Yep, that's the ones. Thanks 4x4high!
  5. iwaxmyjimmy
    Nov 3, 2006
    2,802
    34
    Greenville NC
    sweet, I found brand new rotors for $56 for 2 and Im tryin to find a 3/4ton w/ a 10 bolt front and 14 bolt rear. Going to call my buddy that works at a wrecking yard here in the next hour. I might need to start a build thread here soon. I will definetly have to give you a call here shortly Kurt, I've got quite a list.
  6. cybrfire
    Dec 15, 2002
    15,139
    565
    Iowa
    Lists are good!:wink1:
  7. iwaxmyjimmy
    Nov 3, 2006
    2,802
    34
    Greenville NC
    It will be another month or two before I can get around to doing so but I'll PM you sooner or later.
  8. Supreme70
    Supreme70 1/2 ton status
    Jan 19, 2005
    501
    Detroit, Mi
    Well here are a couple of pics with the DIY4X disc brake brackets installed with 1987 10 bolt calipers and rotors.
  9. thatK30guy
    Jan 12, 2001
    32,076
    55
    Did you ever think about a price quote for your twin caliper mounts that I asked some time back? I'm still interested in some and ready to pay.
  10. iwaxmyjimmy
    Nov 3, 2006
    2,802
    34
    Greenville NC
    Sweet thanx for the pics.
  11. thedrip
    thedrip 1/2 ton status
    Dec 13, 2003
    1,129
    Chattanooga, TN
    how do you bleed your calipers with them clocked up like that? pull them off and rotate them down?
  12. cybrfire
    Dec 15, 2002
    15,139
    565
    Iowa
    Were we doing the twin standard caliper or like the ones I have on my crew cab? Which direction were we headed? Maybe we should go back to PM's. Kind of a hijack here.
  13. Supreme70
    Jan 19, 2005
    501
    Detroit, Mi
    I used a power vacum bleeder for the brakes, you use a air compresser to draw the vacum u need, great tool for bleeding brakes.
