14 bolt disc brake conversion ITEMS?
Discussion in 'The Garage' started by SlyDog, Mar 9, 2002.
  1. SlyDog
    SlyDog 1/2 ton status
    Oct 23, 2000
    3,035
    Scottsdale, Arizona
    What is Everything you need for a disc brake conversion on a 14 bolt?
    Also, while we are at it, what do you need to do a full rebuild of the 14 bolt ? Thanks!
  2. thatK30guy
    Jan 12, 2001
    32,076
    55
    New seals and the simple tools to tear it down and rebuild it. Don't replace bearings and races unless they need to be.
  3. SlyDog
    Oct 23, 2000
    3,035
    Scottsdale, Arizona
    Thanks Wes, BTTT
  4. SCOOBYDANNN
    SCOOBYDANNN 1/2 ton status
    Sep 4, 2001
    2,131
    27
    El Paso, TEXAS
    1. Misfits brackets and spacers ($65.00)
    2. Bolts to hold caliper-2 1/2" long (8 @ $0.80)
    3. Locking nuts on the back of the bolts cause I'm paranoid
    (8 @ $0.65)
    4. 1975 Dana 44 8 lug rotors (2 @ $35.99 w/ 2 yr waranty at Auto Zone.
    5. New seals for the bearings (berings were fine)(2 @ $2.59)
    and a big trash can cause the drums are too big for paper weights /forums/images/icons/laugh.gif
  5. SlyDog
    Oct 23, 2000
    3,035
    Scottsdale, Arizona
    Haha, thanks !
  6. Blazer79
    Blazer79 1/2 ton status
    1,816
    Guatemala, Central America
    What about calipers? Do Misfit's brackets also use 78 Eldorado Calipers?
  7. SlyDog
    Oct 23, 2000
    3,035
    Scottsdale, Arizona
    O ya, I think he forgot to add caliper /forums/images/icons/smile.gif
  8. BigTex
    BigTex 1/2 ton status
    Dec 27, 2000
    974
    South Texas
    Is it possible to use Dana 44 calipers instead of the caddy ones?
  9. 87GMC
    87GMC 1/2 ton status
    Nov 5, 2001
    653
    Olathe, KS 66061
    Yea the dana 44 calipers should bolt in just the same, but without a parking brake.
