14 bolt disc brakes
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by sapper, Oct 17, 2002.
  1. sapper
    sapper 1/2 ton status GMOTM Winner
    Jul 11, 2001
    3,052
    NoVa
    After going outside to compare my 14FF to the one in my wifes truck i got to thinking about useing them brakes. Anybody try this? I dont know if its possible because of the computer and anti lock crap they have but wanted to know if its worth the trip to the bone yard?
  2. Sandman
    Sandman 3/4 ton status Author
    Apr 15, 2002
    5,653
    Pocatello, ID
    Might be easier to buy the Brackets from misfit or somebody and then get the rest at the parts store. This what I did and it was easy and fun to do. (Not really fun) /forums/images/graemlins/grin.gif
  3. dyeager535
    26,975
    First thing you'd have to do is compare the axle flange bolt pattern. If its different, (actual bolt pattern, spacing and number of bolts) you are already looking at needing brackets made.
  4. sapper
    Jul 11, 2001
    3,052
    NoVa
    that was my first tought, just wanted see if anyone had figured out a different way with these factory types?
  5. dyeager535
    26,975
    The later ones should certainly be a better design, it comes down to how effective you want them to be, how much are you willing to pay, and how much time are you willing to spend on them.
    With the Cadi calipers costing what they are, having the problems that they do, the e-brake issues, and the seperate brackets, if you could bolt on the later stuff, I don't think there is a question that newer is better. It's a question of which is easier and cheaper, because the later ones are most certainly better.
  6. BigOrange90Jimmy
    BigOrange90Jimmy 1/2 ton status Premium Member
    May 24, 2002
    2,923
    Wilmington, NC
    What kind of problems do they have? I'm curious as I was about to do this swap.
  7. dyeager535
    26,975
    Well, some problems people complain about are that either the disks don't work very well, the e-brakes are touchy (although I suspect that is owner error most of the time) and apparently they aren't "floating" calipers, meaning they need to be adjusted by using the e-brake..later model stuff is just like the front, and the e-brkae is designed differently.
