14 bolt disc - I read a lot of info, but I'm not finding what I want
Discussion in 'The Garage' started by heavy4x4, Feb 23, 2003.
  1. heavy4x4
    heavy4x4 1/2 ton status
    Aug 28, 2002
    3,270
    Delafield, Wisconsin
    14 bolt disc - I read a lot of info, but I\'m not finding what I want
    I've read a wealth of knowledge on the subject, but I've got some questions:
    1) I see that A-tron's brackets and kits are designed for '85 and older 14 bolts. Why? I'm going to be looking for a 14 bolt newer than '85 specifically for the reason that the parking brake will be less hassle to hook up on my truck. (I'll run drums for a while). So, what's different, and are there kits out there that will work on '85's and newer?
    2) Are there any kits out there that DON'T allow 15" steel wheels to work? I want to stay with 15's for various reasons.
    3) Who here is running the caddy calipers, and where'd you get them - for how much $$? Cheapest I've found is $75 charge and a $70 core (which of course I won't have /forums/images/graemlins/smirk.gif).
    4) For my own clarification - the way the rotors mount is by pressing the lug studs through the backside, right? Does anyone have pics of this? I've read the article in the Bloody Knuckle, and it's great, but is it pretty much the same for 14 bolts?
    Thanks.
  2. One_Ton_k5
    One_Ton_k5 1/2 ton status
    Jan 30, 2003
    168
    St Paul Minnesota USA
    Re: 14 bolt disc - I read a lot of info, but I\'m not finding what I want
    from the shakerbuilt website:
    First, let's get the "Technical" stuff out of the way. This kit "currently" only fits the single-wheel, 14 Bolt, "Full Floater" rear axles from early 1973 to 1985. You can distinguish these rear axles before 1985, because they rear brake drums are held onto the hub with the wheel studs. The drum is unable to slide off without removing the hub. The later (86-up usually) 14 bolt axles have a "floating" drum that you are able to take off and inspect the brakes without having to remove the axle shaft and hub from the axle.
    Yes the studs go into the rear of the rotor and through the 14 bolt hub.
    Hope that helps...
  3. 45acpJr
    45acpJr 1/2 ton status Premium Member
    Jan 7, 2003
    632
    Tucson, Az
    Steve,
    I believe all the conversion kits will allow you to use a 15" wheel, IF you have 2.5" or less of backspacing. If you have more than that you will have to do some caliper grinding, but will still work regarlessly. As mentioned before the studs press thru the rotor and yes there is a big difference between the kits. I sent ya a PM.
  4. tRustyK5
    Jul 23, 2000
    36,180
    1,388
    E-town baby!
    Sean, I run 15" rims with the A-tron disc brackets...3.5" of backspace and no troubles. Maybe rim manufacturers vary a little?
    Rene
  5. 45acpJr
    Jan 7, 2003
    632
    Tucson, Az
    Rene, i just fat fingered the keys I meant 3.5"
  6. u2slow
    u2slow 1/2 ton status
    May 9, 2001
    2,217
    BC Canada
    My '91 has the same 14-bolt used since '73... factory. I've only seen the slide-off drum on 88-up (new style) 1-ton SRW's and 92-up 2500 Burbs w/diesel or BB.
  7. Desert Rat
    Desert Rat Fetch the comfy chair
    Oct 19, 2002
    16,250
    3
    Tri-Valley, NorCal
    Here are some pics from my just finished rear disk conversion. All I have left is to install the calipers. Go here:
    http://community.webshots.com/user/douglasgrant
  8. heavy4x4
    Aug 28, 2002
    3,270
    Thanks for the pics.
    Looks like you've got an awesome build-up going. What'd you use on the frame? POR? And did you sandblast it too?
  9. Desert Rat
    Oct 19, 2002
    16,250
    3
    Tri-Valley, NorCal
    I sandblasted the frame, then did two coats of POR-15, then one coat of POR-15 chassis black. I did two coats of POR-15 on my Corp14 and will finish it off with a coat of POR-15 gloss black topcoat. The stuff ain't cheap, but it does a great job. When I order stuff from Missouri Offroad, A-Tron, ORD or any other place, I usually just tell them to ship it bare metal then POR-15 it myself. Beats the black Rustoleum that most parts come painted with. If a part comes powdercoated, then I leave it alone.
  10. leadfoot067
    leadfoot067 1/2 ton status
    May 14, 2001
    1,563
    puyallup, washington
    TSM manufacturing makes the kits for the 86 and up 14 bolts...they have a pretty good website...www.tsmmfg.com...
  11. heavy4x4
    Aug 28, 2002
    3,270
    Thanks for the link. Anybody use their product? Likes/dislikes?
  12. KrebsATM02
    KrebsATM02 1/2 ton status
    Mar 21, 2000
    553
    College Station, Texas
    what happened to the Official disc brake conversion thread?? I can't find it by searching. I was using that to help me, anyone know where it went? /forums/images/graemlins/confused.gif
  13. Sparky87k5
    Sparky87k5 1/2 ton status
    May 6, 2001
    726
    Lynden, Washington, 4 miles from Canada
    I used the TSM conversion kit on my 84 14BFF in my K5. Great kit and as complete as you could want. Very easy to install. I bought complete kit, rotors, caddy calipers, brackets, flex hoses and all bolts. Came to about $650 delivered. You can piece it together cheaper and do as good a job if funds are a problem. I didn't mind paying the money for a "1 stop shopping" approach.
  14. Derf00
    Derf00 1/2 ton status
    Jul 25, 2000
    1,683
    Abilene, TX
    If you use a 1 ton 14FF, the e-brake is not a problem, it comes down the drivers.
  15. Desert Rat
    Oct 19, 2002
    16,250
    3
    Tri-Valley, NorCal
    My next step is purchasing the Eldorado calipers. I see that the rebuilds that auto stores sell don't come with the e-brake lever and spring as it mentions on the off-road.com write up. Has anyone had any luck at a junk yard finding these or is it just easier to go to a Cadillac dealer and try to order them?
  16. Sparky87k5
    May 6, 2001
    726
    Ypu can buy them thru TSM complete with springs, arms and totally rebult.
  17. Desert Rat
    Oct 19, 2002
    16,250
    3
    Tri-Valley, NorCal
    $300 a pair though? That's a bit steep when the Cardone rebuilds are about $150 a pair loaded. The only thing missing is the arms and spring. I'll have to drop into the Caddy dealer and see how much the arms and spring cost. I can't imagine they would be the difference of $150.
