14 bolt disc questions, WITH PICS!!!!
Discussion in 'The Garage' started by GotLabs, Mar 19, 2006.
  1. GotLabs
    GotLabs 1/2 ton status GMOTM Winner
    Jul 30, 2005
    2,795
    Transient, USA
    I did my disc swap, here are my questions.
    1. is the gap between the caliper bolt and disc supposed be this close?
    2. Is this a detroit? It has four crossshafts jobbies instead of three like the govloc.
    and the stock cucv lugnuts are really hard to tighten. I have some 9/16x18 that work great, but the cucv ones suck. Anyone got some insight on this?
  2. readymix
    readymix 3/4 ton status
    May 30, 2004
    6,706
    26
    Murrieta, California
    That looks awfull close to the rotor to me, but I have not specifically looked at mine. I can run outside if no one else answeres.
    It is a Detroit....see the springs
  3. muddybuddy
    muddybuddy 3/4 ton status
    Jan 29, 2004
    8,933
    Fairfax Station VA
    shouldnt be that clsoe, mine isnt at least
  4. dremu
    Feb 27, 2000
    15,954
    445
    East of San Francisco
    Yeah, the pin seems AWFULLY close. What brand brackets, what kind (or diameter) of rotor?
    -- A
  5. GotLabs
    Jul 30, 2005
    2,795
    Transient, USA
    DIY brackets, the rotors and calipers are 72 3/4 4x.
    I thought that is was, just wanted some reassurance. Glad its not the govloc
  6. sweetk30
    Nov 1, 2004
    25,536
    533
    horseheads , ny 14845
    from the man who wrote the 14ff id guide yes locker. :wink1: and second way to close .
  7. GotLabs
    Jul 30, 2005
    2,795
    Transient, USA
    Any recs on fixing the clearance issue?
  8. 1-ton
    Apr 17, 2004
    2,880
    159
    Las Vegas, Nevada
    Call DIY4X, and see if the rotors you have is the one they designed their system for.
  9. GotLabs
    Jul 30, 2005
    2,795
    Transient, USA
    Thats tomorrow. All the part #s match, I was hoping someone would be able to say "Yeah, just................"
  10. 1-ton
    Apr 17, 2004
    2,880
    159
    Las Vegas, Nevada
    When it comes to modifying a vehicle from it's stock configuration, you have to be ready for it to take time. That is why I say...never modify the sh!t out of a DD, or else you are asking for trouble.
  11. Muddytazz
    Muddytazz 1 ton status
    Jun 30, 2002
    20,073
    Salem, Or.
    I don't know if there is a rotor diameter difference but I know 73 and up rotors all measure the same...maybe 72 is slight bit bigger around :dunno: On mine (I used 75 rotors) I have around 1/4" or so clearance
  12. readymix
    May 30, 2004
    6,706
    26
    75's here too
  13. dremu
    Feb 27, 2000
    15,954
    445
    PartsAmerica (Checker/Schucks/Kragen) lists them the same for '72 and '74.
    I seem to recall that the regular ones are 12" diameter... might check yours?
    -- A
  14. 1-ton
    Apr 17, 2004
    2,880
    159
    Las Vegas, Nevada
    I think the main concern here is...what diameter are the rotors? The year of vehicle they came off of does not matter much because there are so many different determining factors in which diameter rotors a vehicle came with. Measure the diameter of the rotors, and then call DIY4X to see what diameter rotors they designed their system to work with.
  15. highrlr
    highrlr 1/2 ton status
    Nov 29, 2004
    302
    Bismarck, ND
    Will it really matter if the bolt is that close to the rotor if its not actually touching it? Neither of them should move up or down to where they would contact each other right?
  16. GotLabs
    Jul 30, 2005
    2,795
    Transient, USA
    THanks a lot for the info.
  17. GotLabs
    Jul 30, 2005
    2,795
    Transient, USA
    Well I called DIY and spoke with Kert about the issue. I forgot to add in the post that the other side was fine. He is sending another bracket out ASAP. Another reason I like dealing with people on this board! Thanks again.
  18. Masiony
    Masiony 1/2 ton status
    Sep 2, 2005
    729
    Springfield, OR
    all the disk brake conversions say to use 73-87 3/4 ton parts. this may be part of the problem
  19. pvfjr
    pvfjr 1/2 ton status
    Feb 10, 2004
    2,425
    Oakridge, OR
    Well if the other side was alright, that changes everything. If the rotors are the same, then the brackets have to be different. But yeah, the general rotor everyone goes for is 73-87 3/4 ton, part number 5523 I believe.
  20. cybrfire
    Dec 15, 2002
    15,139
    565
    Iowa
    New bracket shipped today. S**t happens. Sorry for the inconvenience.
