14 bolt discs, once again
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by blazbrnc, Aug 3, 2001.
  1. blazbrnc
    blazbrnc 1/2 ton status
    Mar 16, 2001
    181
    southern MI
    I've done numerous searches on this subject, but I still have some questions. I have a 14 bolt ff that I would like to convert to discs. I went to the junkyard an picked up front discs, spindles, calipers, and backing plates off an early 80's 3/4 ton. In most of the 14 bolt disc posts everyone talks about caddy calipers and tsm backing plates. Can I convert to discs with what I have? I'm guessing there may be some machining involved (I haven't tore into the project yet) and that shouldn't be a problem. I don't need e-brakes and the K5 is used 90% off road. I would really like to be able to use what I have and not have to buy anything except new lines and a prop valve. Is it possible, or am I dreaming?
    '79 K5, '79 Suburban, '76 Br**co, 77 K20
    '99 BB 4x4 Suburban to tow more junk home
  2. Boss
    Boss 1/2 ton status Author
    2,550
    Maryland
    Probably would be best to get backing plates for it from TSM or some other people who have made em. That way, you don't have to mess with the spindle. I'm trying to remember how the 3/4 ton caliper brackets are, but I'm not sure if it will work on a 14bolt. Everything else will bolt right on (your rotors and calipers) I'm using 3/4 ton calipers and rotors. No ebrake. But I'm looking into Dshaft ebrakes in the future. Btw, if you need a Adjustable Prop valve, I have one forsale. Never used, "Stainless Steel" brand. I paid $50 plus $6something shipping. I'm selling for $38 INCLUDING shipping.
    Let me know if you're interested.
    Boss
    89' 1 TON of FUN K5
  3. blazbrnc
    Mar 16, 2001
    181
    southern MI
    Hey Boss, Did you use the tsm brackets? Do they have a web site so I can see how spendy they are? One other thing, do the rotors bolt right up to the existing 14 bolt spindle? I've only worked on c-clip axles so I have no clue what I am getting into. Is that the prop valve you used on your conversion?
  4. 45acp
    45acp 1/2 ton status
    Jan 3, 2001
    695
    Tucson, Arizona
    Boss, I would be interested in the proportional valve for $38.00 if you still have it. Send me a address via PM and I'll send a check. Thanks,
    <font color=red> Bill, "Shop Rat" </font color=red>
  5. Boss
    2,550
    Maryland
    Hey, TSM does not have a website. But their brackets alone cost like $145 or something near that....the complete kit that includes the rotors and nuts and bolts is $299. You'll want the flexible hoses as well...another $50. You have the calipers, so you're cool there.
    The rotors will go onto the 14bolt's stock hub. Remove the hub from the drum. Then put the hub on the rotor. Then yes, that will go onto the 14 bolts stock spindle. Understand?
    45acp....I'll send you a PM if this guy doesn't want it.
    Boss
    89' 1 TON of FUN K5
  6. DERBINATOR
    DERBINATOR 1/2 ton status
    Jan 26, 2001
    196
    YANKTON,SD
    When I called TSM a couple of months ago they wanted closer to $225 for just the brackets. I made my own but you can make the brackets you have work. They will have to have the center machined bigger and the bolt pattern changed to match the bolt pattern that holds the drum brake backing plate. Also will need a spacer to get the brackets out where you need them (which I measured the ones on my frontend). As far mounting the rotors you just press the studs out of your 14ff which will seperate the hub from the drum. put your rotor on inplaceof he drumm and press the studs back in. It is really a fairly simple install.
  7. jamiemac
    jamiemac 1/2 ton status
    Mar 26, 2001
    151
    Tennessee
    I bought my disc brake brackets from a guy here on CK5 for around 55.00 bucks. I'll try to find his address. They work great. That damn TSM kit is to damn high. You have everything else that you need. I used D44 calipers,D44 rotors,and D44 front brake lines . Then bent steel lines to the center of the axel where they met the tee. You shouldn't need a proportioning valve. I just hooked mine up to the factory stuff and it worked fine. I can send pics. if you like......
    88 Jimmy,5.7,D44 front,disc brake 14 bolt,4:88 gears,welded front,detroit rear,6" lift
  8. jamiemac
    Mar 26, 2001
    151
    Tennessee
    I believe his name on CK5 was misfit. They fit great. They are a fine product.
  9. blazbrnc
    Mar 16, 2001
    181
    southern MI
    Hey Jamie I am interested in seeing some pics if it isn't too much of a hassle. Send me a PM if you get a chance. Thanks for the help Boss, I'm cheap so I will try to get by without a prop valve if I can (it isn't driven on the street too much).
  10. wakedog
    wakedog 1/2 ton status
    Mar 7, 2001
    233
    Minnesota
  11. Waxer
    Waxer 1/2 ton status Author
    1,857
    Long Beach, CA.
    for the lazy http://www.rockreadyk5.com
  12. mpascino
    mpascino 1/2 ton status
    Jan 1, 2001
    557
    Connecticut
    I'd love to see pics if anyone has em using all chevy parts to do a rear disc swap!!!!! I have all this stuff laying around!
    Thanx,
    Mike
    You call that dirty!?
  13. jamiemac
    Mar 26, 2001
    151
    Tennessee
    All you will need is a set of misfits brackets. Everything else is Chevy parts...
  14. jamiemac
    Mar 26, 2001
    151
    Tennessee
    All you will need is a set of misfits brackets. Everything else is Chevy parts...It works really great.......
    Jamiemac
  15. ScoobyDann
    ScoobyDann 1/2 ton status
    Mar 9, 2001
    305
    El Paso, TX (Far West Texas near Las Cruses
    ill post a pic of the disk swap using chevy stuff and misfits brackets
    sun desert offroad http://community.webshots.com/user/scoobydann
  16. dins1
    dins1 Registered Member
    Jun 3, 2001
    24
    who is making the caliper brakets and how does one get a hold of them. was the nick name misfit?
    72 3/4 ton 4x4 suburban
    71 1/2 ton 4x4 suburban
    79 Camaro RS black & white
    92 GMC suburban 4x4
    All in Webster City, IA
  17. ScoobyDann
    Mar 9, 2001
    305
    To check out the pics for the 14FF disk brake brackets bought off of Misfit Check out the Sun Desert Offroad link, its on photo page 2
