14 bolt discs
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by K5Chris, Jun 7, 2004.
  1. K5Chris
    K5Chris 1/2 ton status
    Mar 11, 2002
    805
    New Orleans, LA
    i know its been covered a million times.... but i couldnt find the info i needed.
    the product review is for a semi floater axle, so it's a bit different...
    sooo....
    i can use 76-78 caddy elderado rear calipers
    or
    chevy front calipers? what years? 1/2 ton or 3/4?
    chevy front rotors? what years? 1/2 or 3/4?
    what kinda prices do these normally run at the parts house?
    just trying to get an idea of what i'm getting myself into.
    my 10 bolt has rear calipers & caliper brackets from an 84-86 mustang SVO (has ebrake) i might see if i can make those work since i already have them..... and, it has ifs front rotors.
  2. imiceman44
    imiceman44 1 ton status
    Aug 5, 2002
    15,160
    Sacramento, CA
    sooo....
    or
    1/2 ton and 3/4 ton calipers are the same.
    Rotors are front from the IFS 88 and up 3/4 ton GM trucks.
    If you can get the Caddy calipers for cheap enough, it would be the easiest.
  3. Muddytazz
    Muddytazz 1 ton status
    Jun 30, 2002
    20,073
    Salem, Or.
    I'm using 1974 front 3/4ton rotors with my caddy calipers /forums/images/graemlins/thumb.gif
  4. dyeager535
    26,979
    Good luck getting the SVO setup to work. If the calipers take a rotor narrower than 1.25", you will find it near impossible to find 6 or 8 lug rotors with the right dimensions. (bolt pattern, thickness, hub "cutout")
  5. K5Chris
    Mar 11, 2002
    805
    New Orleans, LA
    my current rotors are 6 lug IFS light duty (thin) rotors. and, the center hole is machined to fit over the axle flange. your right though..... i prolly wont find 8 lug rotors to fit it.
  6. K5Chris
    Mar 11, 2002
    805
    New Orleans, LA
    OHHHHHHH..... DUDE.......... i'm so retarded..... it never clicked until now......
    i've got a whole complete extra '91 10 bolt front including calipers.... those calipers should work shouldn't they??? sweet.... one less thing i have to buy. /forums/images/graemlins/woot.gif
    hmmmmmm........ i also have an extra set of 6 lug front hub/rotors...... does anybody make a 6 lug hub for the 14bFF..... that, i could put my extra rotors onto the hubs?? that way i wouldnt have to convert the front to 8 lug, wouldnt have to buy new wheels, & wouldnt have to buy rotors for the rear discs..... hmmmm....
  7. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    Just go 8 lug. If nothing else you'll get the piece of mind that you've got 8, 9/16" studs instead of 6, 7/16" studs holding your wheels on. Nobody makes hubs anyway. There are ways to make a 14 ff 6 lug, but it involves machine work.
    Rotors are cheap. Just get yourself some rotors at the parts store.
    Those '91 calipers are going to cause you to lose your e brake, if you care.
  8. dyeager535
    26,979
    So what exactly is the application of the rotors you have on there now, (1988 1/2 ton 4wd? For instance) and how thick are they? Machining the rotor is kind of a pain, but if thats all it takes to use a 1" caliper, it's not too big of a deal, rear rotors should last a long time.
  9. K5Chris
    Mar 11, 2002
    805
    New Orleans, LA
    i dont have an ebrake now..... my calipers are missing the arms that actuate it, and i gave up looking for 84 mustang rear caliper parts...... nobody makes them.... i'll prolly just use my extra calipers until i can afford caddy ones.
    my current rotors on my 10 bolt are 88 front ifs 1/2 ton 4wd regular cab (which i believe has light duty rotors which are thinner) and, they have the center hole machined to fit over the 10 bolt axle flanges. i had them resurfaced not too long ago, and they are cut as thin as they can go. they were real worn before.
    i know, i want to go to 8 lug.... but, the more stuff i have to buy, the longer i have to wait to do the swap. it might be janurary before i can get it done. i've already decided to skip the detroit for now. i have an open carrier that i'll be putting in with the 4.56's, so, whenever i can afford a detroit, i'll just drop it in.
  10. dyeager535
    26,979
    I had checked into the '88 IFS stuff, I couldn't find any that were thin enough to use the 79-85 Cadillac stuff on, or Camaro calipers. Those both use rotors under 1" thick, and even the new Astro's are using 1.25" thick rotors, same as the 73-87 trucks, so I just can't believe there are rotors that thin that were used on trucks.
    If someone can provide me with a part number, I'd be ecstatic though /forums/images/graemlins/smile.gif
  11. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    A brake lathe can always fit a rotor that is slightly too thick you know. /forums/images/graemlins/thumb.gif
  12. dyeager535
    26,979
    .25" isn't slightly too thick. I doubt you can shave that much off a rotor and have any meat left to it. I'd rather go with a rotor that has thicker face but less distance between the two "halves" where the cooling takes place.
  13. tRustyK5
    Jul 23, 2000
    36,170
    1,380
    E-town baby!
    6 lug 14 bolt FF hubs:
    $500 for a pair though.
    Rene
  14. clarkjw24
    clarkjw24 1/2 ton status GMOTM Winner
    Dec 4, 2003
    3,531
    McBee, SC 29101
    Dude just buy the rotors, new calipers, pads, brake lines, bolts from the parts store. All of it new is around $100
