14 bolt - duallie vs. SRW
Discussion in 'The Garage' started by Muley, Jan 30, 2003.
  1. Muley
    Muley 1/2 ton status
    Sep 26, 2002
    364
    Eagle Mountain, UT
    What, if any, are the differences in the 14 bolt FF between these to types of trucks? Do they look different? Is one axle wider then the other? Are the axle tubes different diameter?
    Here is why I ask. I am about to order the spring plate anchors from the dealership so I can do my axle swap. I want to make sure I get the right part since they have to order it in. The u-bolts are no biggy since I can take them home and see right away if they will work.
    Any help would be appreciated.
  2. ZonkRat
    ZonkRat 1/2 ton status
    Jan 16, 2003
    1,003
    Lawrence County Tennessee
    Check out the D60 writeup{It's finally done}in garage.VERY GOOD article. /forums/images/graemlins/crazy.gif /forums/images/graemlins/truck.gifer /forums/images/graemlins/thumb.gif
  3. CHEVY 4WD
    CHEVY 4WD 1/2 ton status
    May 14, 2002
    1,773
    Florida
    I though the duallys used D70's not 14bolts make sure because they look alot alike
