14 bolt dually axle, can it be made to fit?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by mpascino, Aug 28, 2001.
  1. mpascino
    mpascino 1/2 ton status
    Jan 1, 2001
    557
    Connecticut
    I have a 14 bolt dually axle hanging out, taunghting me to go under my suburban. Only problem is I don't think there is enough room to move the spring perches out far enough to make it fit. Has anyone done this swap on a 1/2 ton or 3/4 ton truck? Do you know of any other problems I might run into like the tires hitting the frame? I still have a 14 bolt semi floater also. Could I use the drums and backing plates from the dually axle on the semi floater so I can run the dually set up? Just think it would be bad ass to drive a dually diesel burban around. Thanks for your help.
    Mike
    You call that dirty!?
  2. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    Not sure on if you can use the dually axle but I know that JC Whitney makes dually kits that are bolt-on. Keep your stock axles and your truck can be a dually.
    Tim
