14 bolt dually rear
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by k5blazin, Jan 26, 2005.
  1. k5blazin
    k5blazin 1/2 ton status
    Dec 19, 2004
    262
    Elizabethtown, PA
    I have 2 14bolt dually rears at my shop and i was wondering if i could convert these to run single wheels?? what parts would i need to do this??
  2. readymix
    readymix 3/4 ton status
    May 30, 2004
    6,706
    26
    Murrieta, California
    You will need everything from the backing plates out AFAIK. I do know the axle shafts are the same so it is possible.
  3. k5blazin
    Dec 19, 2004
    262
    Elizabethtown, PA
    i need these parts (backing plate, etc) from a single wheel 14 bolt right?? ill have to see if i can scrounge up some parts.
  4. readymix
    May 30, 2004
    6,706
    26
  5. BlueBlazer
    BlueBlazer 1/2 ton status
    Feb 15, 2001
    1,940
    SRW 14 bolt parts will not work on a dually 14 bolt (assuming this is a Cab and Chassis axle). Axleshafts I think are the same, but where the backing plate bolts on is totally different spot and the axle itself is much narrower.
  6. sweetk30
    Nov 1, 2004
    25,555
    548
    horseheads , ny 14845
    cant you just put on the single wheel rims and see if thay fit.
  7. k5blazin
    Dec 19, 2004
    262
    Elizabethtown, PA
    yea ill see if i can borrow some 8 lug rims from my pop and see if they fit. i guess im better off finding a single wheel 14 bolt though because the brakes arent on the axles i have. all i have are the bare axles with now brakes on them. my dad has them on his truck now :mad:
