14 bolt experts info needed?
Discussion in 'The Garage' started by backyardbuilt, Feb 3, 2003.
  1. backyardbuilt
    backyardbuilt 1/2 ton status
    May 28, 2002
    1,301
    Olathe, Kansas
    Here are some pics of 2 axles both from 14FF's, obviously they are different were there different shafts for the vans as far as spline diameter and axle width the small one is about 1.25 and mine is the 1.5 it is supposed to be plus the flange end has a dimple in the back side where mine is flat. help!!
  2. u2slow
    u2slow 1/2 ton status
    May 9, 2001
    2,217
    BC Canada
    That little one is a Spicer shaft... probably from a Dana 60. The small holes in the domed axle flange, and the fluted hub (judging from the silicone pattern) are a dead wringer.
  3. thebigdaddyof2
    thebigdaddyof2 1/2 ton status
    Dec 28, 2000
    2,053
    St. Louis, Missouri
    Doesn't look like a 14BFF shaft to me. A van 14BFF is identical to a 3/4 or 1 ton 14BFF except that it is wider. Same spline count- same shaft diameter, Batman.
  4. TOMER
    TOMER Registered Member
    Sep 20, 2002
    38
    Israel
    It look's like a semi float shafts to me ?!?!
  5. 79Jimmy
    79Jimmy 1/2 ton status
    May 10, 2000
    214
    Richmond BC, Canada
    Better check your persciption /forums/images/graemlins/ooo.gif.....I agree with u2, the shaft on the right looks like a D60 rear full floater shaft.
    James
  6. bigmack
    bigmack 1/2 ton status
    Jan 3, 2002
    478
    Tennessee
    As far as the smaller one on the right, I would also say it's from a D60, or possibly out of an old Eaton "pumpkin" rear end that the older GM's came with ??
  7. backyardbuilt
    May 28, 2002
    1,301
    Olathe, Kansas
    It is a dana 60 found out that when the guy bought the axle the shafts were laying next to it not in it so he just assumed they were 14 FF. Thanks for the replies all is good now.
