14 bolt F/F or S/F?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by badthorn, Aug 9, 2000.
  1. badthorn
    badthorn Registered Member
    Aug 9, 2000
    17
    I want to know which one is better and how can I identify which one is what?
  2. Emmettology 101
    May 9, 2000
    8,126
    FL
    the FF has a 10.5 ring gear and the s/f has a 9.5 ring gear. The FF will have a "hub like" protrusion from the wheel that has 8 or so small bolts on it that hold the axle in, the s/f will look like a 12 bolt with no protrusion.
    The FF has a "floating axle" and the truck rides on the bearing and just spins the axle(somewhat blunt but..) The s/f the truck rides on the axle and the bearing so the bearing is kind of doing double duty.
    The FF is stronger, but you will loose about @ inches of ground clearence, where ith the s/f, you only loose an inch if you are moving up from a 12 bolt.
    I heard someone say tht the strength of a 14 s/f is abut equivalent to a D60, but I dont really know.
    As far as which one to get, that seems to be a personal opinion. Some like the FF for Brute strength an some like the s/f for better ground clearance and a little lose of strength compared to the FF.
    HTH, BTW I have a s/f for sale in the Parts forum. :)
    Mike [​IMG]
    1982 GMC Jimmy - <font color=green>Emmett</font color=green>
    http://emmett.coloradok5.com
  3. ggallin13
    ggallin13 1/2 ton status
    Mar 31, 2000
    199
    Northern Nevada
    I have an S/F supposedly, but I have the hub-like protrusions and my pumpkin is huge. I do have 6-lug wheels, though. Maybe I have some sort of hybrid???
  4. tRustyK5
    Jul 23, 2000
    36,175
    1,385
    E-town baby!
    I have never seen a F.F. 14 bolt with 6 lugs. As far as I know they all come with 8 lugs. Look in the technical section of this site. There is an axle identification section, this should clear up any confusion [​IMG]
    Rene <font color=red> 81 K-20 Jimmy </font color=red>
    <font color=green>[​IMG]"God hates a coward"</font color=green>[​IMG]
  5. 84k5
    84k5 1/2 ton status
    May 13, 2000
    2,949
    Dublin, CA
  6. ggallin13
    Mar 31, 2000
    199
    Northern Nevada
    I checked the axle chart on the tech page, and mine is the "heavy" one, and I have 6-lug wheels. I was curious since I have the hub-like thing coming out through the center of the wheel.
  7. tRustyK5
    Jul 23, 2000
    36,175
    1,385
    E-town baby!
    Well [​IMG] damned if I did'nt learn me sumptin today [​IMG]. Thats pretty cool.
  8. 6.2Blazer
    6.2Blazer 1/2 ton status
    Feb 24, 2000
    4,675
    26
    Ohio
    Is there anyway you can post a picture of your rear diff.....I'm just curious as to what you have.
  9. ggallin13
    Mar 31, 2000
    199
    Northern Nevada
    Sure, I can get some pics up in a day or so, no problemo. I am curious to see what I have myself! As I mentioned before, the pumpkin looks exactly like the full-floater on the axles tech page, and I have the hub protrusions but I have 6-lug wheels. The axle cost me $1000, but so far it is well worth it.
  10. Shawn
    Shawn 1/2 ton status Premium Member Author
    1,753
    5
    5280'
    Not sure if this helps but here's a FF 14 bolt showing the hub. (I started to remove the hub bolts for the TSM install)
    Is this what yours looks like except it has 6 lugs?
    Oh yeah, notice the eight hub bolts. If yours has the 8 hub bolts and the 6 wheel lugs, then I'm at a loss since I've never seen that.
    Sorry the picture is so big.
    Shawn
    87 K5
    few mods
  11. ggallin13
    Mar 31, 2000
    199
    Northern Nevada
    That's it exactly, except that the bolts on mine are smooth, with a hex on the inside. There are eight of them, and I have 6-lug wheels. Pics in a day or so, but in the meantime your pic fits the bill! The guy who sold it to me said that it was a rebuit axle from a tow truck, if that means anything.
  12. Shawn
    1,753
    5
    5280'
    WEIRD! You may just have a very rare axle. Wanna sell it??? Just kidding!
    Shawn
    87 K5
    few mods
  13. Donovan
    Donovan 1/2 ton status
    524
    Arvada, CO
    Are you sure you can't get them pictures faster? Just kidding. You got use die to see these pictures. [​IMG]
    Donovan
  14. BillyBob
    BillyBob 1/2 ton status
    Feb 23, 2000
    557
    Dumont, NJ
    I was wondering, I'm planning on looking for a 14 bolt S/F, since I do wanna keep my truck 6 lug. The question I have is, will the S/F be okay to use with 35s and a 4" lift? That's about as big as my truck is getting. The truck doesn't do any hardcore offroading. It plays in the mud and it went on some rocks a few weeks ago. I also plan on keeping it a daily driver, since insurance is insanely high in NJ, and I can't afford to have another vehicle. So, will the 14 bolt S/F be the perferable swap?
    http://billybob.coloradok5.com
    It's all fun 'n games, till someone gets stuck.
  15. ggallin13
    Mar 31, 2000
    199
    Northern Nevada
    The lift you have has little to do with the axle you have. You could run a 14-bolt with no lift at all, but your rear diff would be REALLY low, as you wouldn't be able to run big tires. Steve, the site admin is running a 14-bolt FF with a 4" lift, so I am sure you'd be fine.
  16. 6.2Blazer
    Feb 24, 2000
    4,675
    26
    Ohio
    I would say the s/f 14 would be more than strong enough for 35" tires. If you look at the specs, the s/f 14 should be pretty comparable to a Dana 60.
    Ggallin - what is the diameter (how big around) is the protruding hub? Do you have the standard 6 on 5.5" wheels. The reason I'm asking is that it seems like on a normal f/f 14, the protruding hub is too large to allow enough room for the center hole in the rim and the lugs to fit. Maybe you have a custom machined hub?
  17. ggallin13
    Mar 31, 2000
    199
    Northern Nevada
    My wheels are the standard 6 on 5.5 The protruding hubs look like a tight fit, but I don't think that anything was ground off of them. Pics will be up later today, I am going to drink some beer and have some food, then get a disposable camera and shhot some shots o' the axle.
  18. Shawn
    1,753
    5
    5280'
    Just don't over do it on the beer! I want to see pics of the hub and not something you may encounter at the bar with beer goggles!
    HAHA Just kidding [​IMG]
    Have a good one!
    Shawn
    87 K5
    few mods
