14 bolt F.F. questions
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Daveytree, Feb 3, 2001.
  1. Daveytree
    Daveytree Registered Member
    Nov 11, 2000
    57
    Kingman Arizona, U.S.A.
    As some of you may know my truck went up in flames on my way to Arizona. I am down for now but, there is another K5 in my future hopefully soon.
    Here is my question. I may have the opportunity to pick up a 2 wheel drive 3/4 ton to get around in until I can afford the truck I want. I was wondering if the 14 bolt in the 2wd would work for a rearend swap? My old truck had 3/4 ton but all the stuff came out of a 4wd. I just needed to know if there was any differences. Any input would be appreciated. Thanks.
  2. yeild2me
    yeild2me 1/2 ton status
    Jan 7, 2001
    1,309
    fayetteville, nc
    i got my ff out of a 2 wheeler....its still in the garage, but all the measurements jived...from what ive read on here, they are all the same, thats why i got mine..looks like you got a good driver that will supply a rear axle!![​IMG]
    AIRBORNE!!
  3. Daveytree
    Nov 11, 2000
    57
    Hey thanks for the info. Very helpful in my decision.
  4. thatK30guy
    Jan 12, 2001
    32,076
    55
    As long as the rearend is from a 3/4 ton donor truck, it will work. If you had a one ton, the spring perches are closer together and the shock mounts are opposite sides of each other.
    There also is a difference in 2WD and 4WD rearends. The 2WD shock mounts hang down lower than the 4WD's. Just if you have a 2WD rear, make sure your shocks, if you get new ones, are longer than the specified 4WD length. Generally, add approx. 2 more inches to the shocks for the longer travel.
  5. Daveytree
    Nov 11, 2000
    57
    Thanks for the info about the shock mounts. I had no idea about that but I figured somebody would.
