14 bolt FF - 8lug to 6lug????
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Tommy, Mar 12, 2000.
  1. Tommy
    Tommy 1/2 ton status
    Feb 21, 2000
    260
    Alabama
    I havew just aquired a set of 3/4 ton front and rear axles. I know I can put the 6ug knuckles on the front, but has anyone ever redrilled or had the rear hub converted over to 6lug? My reason is I have a brand new set of Weld Wheels, and would like to keep them. Any Input????
  2. Corey-88K5
    Corey-88K5 1/2 ton status
    720
    Home: Michigan, Stationed: Hill AFB (Home of Moab.
    Don't hold me to this, but I think there are some aftermarket suppliers that will make a axle shaft & hub that will allow 6 lugs for the 14blt. I just went with a s/f 14blt for my application.
    Corey88K5
    [​IMG]<font color=blue>Girls Like Guys In Bow Ties</font color=blue>
    <font color=red>http://www.geocities.com/corey_perez
  3. Tommy
    Feb 21, 2000
    260
    Alabama
    Thats what I've been told, there is a source of the 6 lug hub, but who?
  4. Corey-88K5
    720
    I'd try either Currie, Dynatrac, confer or warn. These all make replacement axles.
    I think Dynatrac would be your best chance though. They can make about anything.
    Corey
    88K5
  5. Chris Demartini
    2,406
    Dumont NJ 07628
    <font color=blue>Hey Corey, I'm planning on swapping in one of these rears since i will never need a ff because the max. tire hieght by law [​IMG] in nj is 38". What did you have to do to put this axle in? what rim size/backspacing did you use? Who make alloy shafts and where can I get them? thanks</font color=blue>
  6. 6.2Blazer
    6.2Blazer 1/2 ton status
    Feb 24, 2000
    4,675
    26
    Ohio
    I don't think it's possible to re-drill the stock hub and rotor for a 6 lug pattern. The reason is that the diameter of the protruding hub (where the end of the shaft bolts on) is big enough that there isn't enough room for the smaller 5.5" diameter 6 lug pattern. The only way I can see to do it is a completely new hub and axle.
    Let's us know if you have any luck.
  7. IDGMC
    IDGMC 1/2 ton status
    Feb 18, 2000
    150
    Idaho
    what sizer are your rims?? if they are 15" they won't work on a 14bolt anyways....correct me if i'm wrong but don't you need at least a 16" rim to fit on one of those?
  8. White Knight
    White Knight 1/2 ton status
    889
    Ft Worth,Texas
    The only way to fit 15's is to change out the drums on the 14 ff to a disc brake conversion, TSM makes these at a reasonable price also. The drums are too large to stuff a 15 rim around....WK
  9. Goose
    Goose 1/2 ton status
    1,127
    South Central Kansas
    What about the front? Won't the disc calipers on the 3/4 ton, 8 lug axle make 15" rims useless? Or is it just the 1 ton, 8 lug axles?
  10. Corey-88K5
    720
    Biggray71,
    I got a 93 3/4 ton S/F out of a P/U. I still don't have the axle under the truck. It currently sitting in the carport. I'm getting ready to make some perches like Depdog. As soon as I get that done, the axle will be ready to go in. I've already got the TSM conversion (15" wheels will fit on s/f 14blts with no problem), new lines, stock perches are ready to be put on if needed, and the "trick U-joint". So, as soon as I get off my arse, it will be in...
    Corey
    88K5
  11. ken
    ken 1/2 ton status
    1,244
    Anaheim, CA
    CORRECTION, 15" wheels WILL FIT onto a full floating 14 bolt rear IF the rear has the 11" brakes. These rears were used in light duty 3/4 tons, like 6800 GVW, just like my factory light 3/4 ton '77 Suburban 4x4. These 11" brakes are the same as the 12 bolts of the era.
    ken
  12. Tommy
    Feb 21, 2000
    260
    Alabama
    If thats the case, my axles came out of a 78 suburb, could I redrill the hubs, then use the 12 bolt brake drums? Just a thought.
  13. ken
    ken 1/2 ton status
    1,244
    Anaheim, CA
    NO
    ken
