14 bolt FF advice please
Discussion in 'The Garage' started by sope, Oct 8, 2005.
  1. sope
    sope 1/2 ton status
    Jul 8, 2005
    967
    British Columbia
    I have a couple of questions.
    1:On a pre "88 truck is the width of a FF 14 bolt from a dually different from a single wheel truck.
    2: For the guys running front 10 bolts or Dana 44's and rear 14 bolts, do the big drums cause any problems, like rear brake lock up.
    I'm thinking of finally putting the big diff in so I would appreciate your comments,
  2. BigCountryx
    BigCountryx 1/2 ton status
    Feb 19, 2005
    519
    Gonzales, LA
  3. u2slow
    u2slow 1/2 ton status
    May 9, 2001
    2,217
    BC Canada
    Yes. Its narrower.
  4. K5MONSTERCHEV
    K5MONSTERCHEV 1/2 ton status
    Jan 27, 2003
    3,254
    Castro Valley, CA
    I never had any brake issuse with my 14 bolt and 10 bolt. Unless I had to put my foot to the floor, then that was fun, but normal everday driving, no problems. Just keep in mind everyones truck is different, nothing a little adjusting cant fix.
  5. sope
    sope 1/2 ton status
    Jul 8, 2005
    967
    British Columbia
    Thanks for the help. Got what I needed to know.
  6. sope
    sope 1/2 ton status
    Jul 8, 2005
    967
    British Columbia
    I've been checking out the link Big Country X gave me and for width of differentials it sys 67.5" WMS-WMS. I'm not sure what WMS is. Does it mean to machine surface of hub where axle bolts on or where wheel bolts on? Am I way off? Anybody know? :confused: :confused: :confused: :confused:
  7. sweetk30
    Nov 1, 2004
    25,538
    538
    horseheads , ny 14845
    w=wheel
    m=mounting
    s=surface
    and the dully has totaly diffrent brake dimensions even the flang on the axle where the backing plate bolts on is spaced diffrent.
    if you need a single setup just find one if dully just find one. much easyer than converting one. also if single and want track width to match the front van axle 3" wider .
  8. sope
    sope 1/2 ton status
    Jul 8, 2005
    967
    British Columbia
    Wheel mounting surface. Seems pretty obvious now. :doah:
    Thanks for the advice.
  9. 4xcrazy
    4xcrazy 3/4 ton status
    Oct 31, 2003
    9,471
    5
    Olympia/Lacey, Washington
    yes, mine did, i kept the stock 1/2 braking crap on the front, and switched to the bigger 3/4 ton 13.5"x2.5" drum setup, and was having some problems with rear braking, was locking up too easily, sounds weird, but when i switched to the larger rotors up front it was not as noticable, then went to rear disk, and is non-existant, the brakes all work, but still feel alittle "soft" at times, i think i still need to work out some bugs in the system.
  10. sope
    sope 1/2 ton status
    Jul 8, 2005
    967
    British Columbia
    I Guess I'll have to try and see how it is. I won't be converting untill I find some 8 lug front end parts and 8 lug rims used. I figure I'd better stay with the 10 bolt up front cause I've already got 3 year old inner and outer axles and a detroit locker in the front. I don't want to pay for the D60 and again for the locker. Disks on the rear sound good but I already have a ride height rear brake limiter in my tool box I figure I could try this. Has any one ever tried this when converting to 14 bolt rear?
  11. u2slow
    May 9, 2001
    2,217
    BC Canada
    I have the brake limiter valve on my Crew and Burb. I'm not convinced they are effective. The one on my Burb is now disconnected since I swapped in the 14FF. IMO, either truck is fine with full-force braking on the 13x3.5" drums because they have so much weight over the axle anyways (Crew has a logger's box BTW).
  12. skelly1
    skelly1 1/2 ton status
    Sep 2, 2002
    554
    San Diego, CA
    I'm not an expert, but when I went to the 14bff in the rear/ 8 lug d44 front, I changed the master on my 1990 to a 3/4 ton master and it stops better than it ever did. The front brakes are a joke too. The rotors had been metal to metal on the front axle for who knows how long, were rusty as hell and I just put my old calipers and worn out pads on the front. To make a long story short, even with front brakes that were way less than ideal, the big rears with a 3/4 ton master made it stop better than with good 1/2 ton brakes all the way around.
