14 bolt ff and sf
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by 1979Jimmy, Jul 8, 2002.
  1. 1979Jimmy
    1979Jimmy 1/2 ton status
    Nov 14, 2001
    696
    Danville Ca
    I was curious what the difference in strength was between FF 14 bolts and SF 14 bolts. I did a search but it didnt turn up much.
  2. 73k5blazer
    Dec 28, 2001
    4,987
    38
    The Rustbelt
    On a full float axle the axle shafts are only rotating the the drum and wheel. They don't carry any weight, the axle housing does that. On a semi-float axle, the axle rotates the drum and wheel, as well as carries the weight of the vehicle at the same time. Also, the semi-float axle shafts are held in with C-clips, which means if you snap an axle, the whole wheel/tire/drum/axle stub will slide right out. On a Full float, if you snap an axle, while is more unlikly anyhow, but if you do, just take it out and your tire/wheel/drum stays attached to the housing allowing you to drive home.
    Here's the differences in specs:
    Axle Ring Dia. Spline Count Axle Shaft diameter
    14BFF 10.5" 30 1.5"
    14BSF 9.5" 33 1.37"
    Dana 44 8.5" varied usally 1.31"
    Dana 60 9.75" 30 or 33 1.31 or 1.50"
    Dana 70 10.5" 23, 32, 35 1.5, 1.31, 1.5
    BlazerMan
  3. Muddytazz
    Muddytazz 1 ton status
    Jun 30, 2002
    20,073
    Salem, Or.
    I am running a D44 in the front and 12 bolt in the rear that are semi float in a 75 K10 Suburban, they are stock with the stock 3.08 gears...I am wanting to change the gears to 4.10's....anyways, the question i have is, I want to put full float axles in, do they make full float for 1/2 tons?
  4. HarryH3
    HarryH3 1 ton status Author
    May 31, 2000
    10,384
    Georgetown, TX
    Warn makes a full floater kit for the 12-bolt. I think the kit runs about $850. Check out www.offroaddesign.com I think that Stephen sells the Warn kits. /forums/images/icons/cool.gif
