14 bolt FF axle 'plates'- use RTV?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Mudstud, Apr 28, 2003.
  1. Mudstud
    Mudstud 1/2 ton status
    May 29, 2001
    1,472
    Memphis, TN
    14 bolt FF axle \'plates\'- use RTV?
    You know the metal plates that act like a gasket at the ends of the axle? Bolt between the hub and shaft? Are you supposed to replace these each time you take an axle out or what? Should I use some silicone or RTV to help seal them?
    Also, how do you get the outter bearings out of the hub/new ones in? They don't fit through the hole in the hub.
  2. 2Dogs
    May 4, 2001
    3,470
    35
    Ca
    Re: 14 bolt FF axle \'plates\'- use RTV?
    I used silicone since those gaskets were hard to find. Put a little on the bolts also.
    All the bearings come out the big end of the hub /forums/images/graemlins/grin.gif
  3. Hossbaby50
    Hossbaby50 3/4 ton status
    Sep 1, 2001
    8,972
    Peoria, AZ
    My metal gaskets on mine were a little beat up so I got them as straight as possible and coated both sides with RTV. It has held fine for over 9 months now so I can't complain.
  4. 82TOYLB
    82TOYLB Registered Member
    Nov 28, 2001
    61
    Sacramento California
    Those little metal gaskets are a dime a dozen and very available here in Sac. I think any local NAPA should have them for a buck or so.
  5. MTBLAZER89
    MTBLAZER89 3/4 ton status Premium Member GMOTM Winner
    Aug 14, 2001
    7,272
    237
    Oak Harbor, WA
    Look closely inside there is a snap ring. Pull it out then you can get the bearing out. Then you can tap out the race. I said the same thing last week /forums/images/graemlins/rotfl.gif How the hell does this come out??
    -Brian
