14 Bolt FF Axle Seals ......... Arghhhhhh!
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Stoopalini, Feb 6, 2001.
  1. Stoopalini
    Stoopalini 1/2 ton status
    Oct 17, 2000
    999
    Austin, Texas
    The Corp 14 ff has wheel seals in the drums because the fluid travels all the way to the ends.
    When I first installed the diff, I replaced both seals just for good measure. About 2 days later, the drivers side started leaking so I replaced it again.
    It has been fine for about a week, and now both of them are leaking!!
    Whats going on here? Anyone have experience with this type of problem? Maybe I should just get 2 new drums, but I don't even wanna know what that will cost me!
    Thomas.
    -- '84 K5 Blazer --
    <A target="_blank" HREF=http://Stoopalini.coloradok5.com>http://Stoopalini.coloradok5.com</A>
  2. BIGJ
    BIGJ 1/2 ton status Author
    896
    Central Arkansas
    Check the spindle's. There is probably a groove worn in the spindle, and that's why it's leaking. I have heard of guys using a speedy (sp?) sleeve to go over the grooves. If you search the posts, the guy that suggested the sp sleeve even gave the part number he got from national drivetrain. I had the same problem, I just moved the seal about 1/16" in to clear the groove. I'm buying sleeve's next time.
    BIGJ
  3. elkboy
    elkboy 1/2 ton status
    Aug 18, 2000
    293
    Hillsboro Oregon
    I've done the offset the seal lip from the groove trick, and it works pretty good if you anly have one groove. If a groove is not the problem, try buying good quality seals from NAPA. Cheap seals suck and somtimes distort during installation. Also, use a bit of grease on the seal surface during installation to keep it lubed until the oil gets flowing.
    good luck
    [​IMG]<font color=red> Elkboy</font color=red> [​IMG]
  4. HarryH3
    HarryH3 1 ton status Author
    May 31, 2000
    10,384
    Georgetown, TX
    Also make sure that the axle vent tube isn't blocked. Heat expansion will cause the seals to leak if the pressure can't escape via other paths.
  5. Stoopalini
    Oct 17, 2000
    999
    Austin, Texas
    Cool! Great info guys ..... thanx!
    I got the seals at Autozone, and that was probably my first mistake. I'll buy the next 2 from NAPA.
    I installed them by greasing them up and pressing them in with my press. Should I not be using the press to do these?
    Thomas.
    -- '84 K5 Blazer --
  6. BIGJ
    896
    Central Arkansas
    I use a race/bearing driver to install the seals. It' s a big seal, bigger than my race driver could handle. I bought a 3" puck of aluminum and had it turned at a machine shop to fit the seal and races of my 14 bolt. It cost me about 20 bucks and is a lot easier than using a socket for all the races and seals, and probably quicker than using a press.
    BIGJ
  7. Stoopalini
    Oct 17, 2000
    999
    Austin, Texas
    I just used the metal plates that came with my press to press them in. They are a lot bigger than the seal, but the seal seems to fit even with the inside of the drum ..... is this incorrect? Is the seal supposed to sink inside the drum?
    Now I'm confused [​IMG]
    Thomas.
    -- '84 K5 Blazer --
  8. titanic
    titanic 1/2 ton status
    Mar 27, 2000
    498
    north alabama(huntsville)
    If the spindle has grooves-moving the new seal slightly in or out will work for awhile but as soon as you get into a little mud, they will start leaking. The speedy sleeves work, have Not had to replaces seals since 1994 and I done alot of deep mud crossings since then. Tip on install. the speedy sleeves: Get a piece of muffler pipe and flare the pipe just so it'll clear sleeve. The sleeves come with a flange that can be broken off after installing them but leave it on and it will protect the seal face somewhat
  9. Smitty
    Smitty 1/2 ton status
    Sep 1, 2000
    999
    Crestview, FL
    Part # for the sleeves is 99282. The number is good for National and Carquest brands.
    Smitty
  10. Stoopalini
    Oct 17, 2000
    999
    Austin, Texas
    Is this the groove you guys are talking about?
    Any help is GREATLY appreciated!
    Thomas.
    -- '84 K5 Blazer --
  11. Executioner
    Executioner 1/2 ton status
    Feb 22, 2000
    1,530
    Temp. Ft. Walton Beach Fl. home=Tucson, Az.
