14 Bolt FF axle swap questions
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by 88sub4x4, Sep 22, 2002.
  1. 88sub4x4
    88sub4x4 1/2 ton status
    Sep 22, 2002
    792
    Long Island, NY
    I am interested in swapping out my 10 bolt rear in my 88 suburban for a 14 bolt FF. I read the article in the technical section but am a little confused as to what this means.
    "On newer Chevy's, the brake backing plate (picture H) will have to be changed to a press in style backing plate from a 14-bolt (SF) with 13" brakes."
    So I will need a SF backing plate? What is the reason for not being able to use the backing plate that is already on the 14 bolt FF?
  2. azblazor
    May 5, 2001
    1,953
    Arizona, Phoenix area
    I would think it has to do with the e-brake cable arrangement. I think other solutions can be devised.
  3. stan2d2
    stan2d2 Registered Member
    Mar 29, 2001
    39
    NE Pennsylvania
    I did the swap on my 88 Jimmy. The donor diff was from an 80 3/4 ton Chevy. I had to take off the backing plates to modify it to take the push in style E-brake cable. My brother had some scrap pieces of metal and built it up like what the stock 10 bolt plates looked like and drilled the holes out to take the cable. Other then that it was an easy swap. I did try ordering new backing plates to match but the dealer said they were unavailable.
  4. BlueOx
    BlueOx 1/2 ton status
    Aug 6, 2000
    239
    Houston, Tx
    I modified the backing plate on mine to make it work. I had the same prob as you and just did a little fix.
    I'll post some pics in a few so you can see.
    Charles
