14 bolt FF bearing lubrication
Discussion in 'The Garage' started by BlitzK5, Jul 30, 2005.
  1. BlitzK5
    BlitzK5 1/2 ton status
    Jul 29, 2005
    288
    Sherwood Park, Alberta, Canada
    I just got my 14 bolt FF and when I pulled the hubs off I noticed there was no grease in the bearings. DO these bearings get there lubrication from the differential fluid or should they be greased just like the front bearings. If so, does this mean I can just slap in new ones with nothing on them and then im done?
  2. sweetk30
    Nov 1, 2004
    25,553
    547
    horseheads , ny 14845
    oil from diff is lube. i just dip them in fresh oil first and install them. drive it a bit and recheck diff level.:wink1:
  3. BlitzK5
    Jul 29, 2005
    288
    Thanks alot.
  4. sweetk30
    Nov 1, 2004
    25,553
    547
  5. BigCountryx
    BigCountryx 1/2 ton status
    Feb 19, 2005
    519
    Gonzales, LA
    I must be an idiot, wondered about this too, but I packed my bearings with hitemp bearing grease and installed them before thinking. When I tore it apart, they had been greased before so I thought I was doing good at the time. Guess I got a project for monday, tear apart hubs on 14ff and clean all the grease out. :doah:
  6. k5freak44
    k5freak44 1/2 ton status
    Jun 1, 2004
    2,164
    Plano, TX
    its not going to hurt anything if they are greased.
  7. BigCountryx
    Feb 19, 2005
    519
    Gonzales, LA
    Are you sure, the axles are on stands in my garage right now, so I could clean the grease out if need be, but if I don't have to I won't, canyou say PITA :crazy:
    Anybody else have an opinion on this? Clean or let it eat?
  8. Muddytazz
    Muddytazz 1 ton status
    Jun 30, 2002
    20,073
    Salem, Or.
    I packed my bearings with grease when I installed new bearings and that was 3 yrs ago. Still running on the same bearings with not a problem :thumb:
  9. BigCountryx
    Feb 19, 2005
    519
    Gonzales, LA
    :saweet: :pimp:
  10. txfiremank5
    txfiremank5 1/2 ton status
    Jul 6, 2004
    3,105
    San Antonio, TX.
    Another vote for leave it be. Some people grease 'em, some just dip 'em in the oil. Either way is fine.
  11. jhellwig
    jhellwig 1/2 ton status
    May 7, 2005
    420
    Bonaparte, Ia
    The greese will just melt into the oil. In something like that there can never be to much lubrication.
  12. blazinzuk
    blazinzuk Buzzbox voodoo Premium Member GMOTM Winner
    Dec 20, 2002
    17,412
    3,799
    Afton / Star Valley Wyoming
    Some grease will stay on them too my breather got plugged once and it built up enough pressure ( at least this is what I think happened) that once it unplugged itself I was left with not much gear oil in the diff I didn't ruin any bearings and I do grease my outside bearings
  13. Chaddy
    Chaddy 1/2 ton status GMOTM Winner
    May 23, 2005
    4,110
    Salt Lake City,Utah
    No grease in the 14b at all. the hubs are bathed in 90 weight.
  14. walla2k5
    walla2k5 1/2 ton status
    Sep 5, 2004
    2,054
    Walla Walla, WA
    I grease everything,just a habit....
