14 bolt ff carrier bearings..
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by yeild2me, Feb 22, 2001.
  1. yeild2me
    yeild2me 1/2 ton status
    Jan 7, 2001
    1,309
    fayetteville, nc
    if i change my carrier bearings, will the gears need to be set up again? or can i just mark the adjusting sleeves, remove the carrier, install the new bearings, install the carrier, and tighten the adjusting sleeves to where they originaly were?
    thanks
    AIRBORNE!!
  2. CK5
    May 19, 1999
    21,623
    701
    CO
    You do not have to set up the gears again, because you are not touching the pinion depth/preload or anything, but after you install the new bearings you still want to use some marking compound to check the wear pattern and adjust if necessary, the adjusting sleeves are what control the side to side movment of the ring gear in relation to the pinion. someone correct me if I'm wrong please, but I believe this is the case.
    Steve
    Mall-Running poseur 4x4 with curb-feelers
  3. Executioner
    Executioner 1/2 ton status
    Feb 22, 2000
    1,530
    Temp. Ft. Walton Beach Fl. home=Tucson, Az.
    Please learn the term carrier bearing pre-load
    Thank you
  4. thatK30guy
    Jan 12, 2001
    32,076
    55
    Yes, master!!!
  5. CK5
    May 19, 1999
    21,623
    701
    CO
    Your Welcome
    Steve
  6. thatK30guy
    Jan 12, 2001
    32,076
    55
    Aye, aye, captain!!
