14 Bolt FF Carrier
Discussion in 'The Garage' started by 1HighK5, Apr 24, 2005.
  1. 1HighK5
    1HighK5 1/2 ton status
    Feb 7, 2005
    140
    New York
    Hello everyone I would just like to know because I'm not totally sure. Do you need a different carrier to run 4.56 gears? The 14 Bolt I have has like a 3.42 or somthing they are highway gears. Will I have to hunt down a different carrier to go to 4.56 gears? Thank you John
  2. sweetk30
    Nov 1, 2004
    25,526
    526
    horseheads , ny 14845
    4.10-down and 4.56-up is the split
  3. Hossbaby50
    Hossbaby50 3/4 ton status
    Sep 1, 2001
    8,972
    Peoria, AZ
    The carrier split is 4.10 and lower and 4.56 and higher. To run normal 4.56 gears you will need a new carrier. BUT
    They make "thick" version 4.56 gears that will work on your 4.10 carrier. I personally run 4.56 thick gears on a carrier that used to have 3.73's on it. So the answer is NO you don't need a new carrier.
    Harley
  4. mini_mull
    mini_mull 1/2 ton status
    Jan 22, 2005
    1,198
    Queen Creek, AZ
    Are there any disadvantages to running "thick" gears, other than you can't get anything lower than 4.56? Can you run all the same lockers as long as you order the ones meant for the 4.10 down carrier?
  5. atho
    atho 1/2 ton status
    May 14, 2003
    1,115
    Wayne County, Ohio
    they also make 5.13 "thick" gears, and the lockers will fit in either carrier.
  6. 85mudblazin
    85mudblazin 1/2 ton status
    Mar 26, 2004
    3,951
    Austin,TX
    I dont see any disadvantages, the ring gear is thicker so it in theory will be stronger.
  7. jk5blazer
    jk5blazer 1/2 ton status
    Jan 28, 2005
    306
    Braselton, Ga
    none, all you need is the thick gear. Nothing different about install, other than installing a thicker gear.
