14 bolt FF converison question.
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by shum1, Mar 5, 2001.
  1. shum1
    shum1 1/2 ton status
    Oct 8, 2000
    270
    UTAH
    I found a 1983 3/4 ton van with a 14B SF axle in it. The breaks are 13" The e-brake cables are both routed to the drivers' side. Are these the backing plates I need to make the 14B FF axle work in my 1990 rig? Do they just unbolt? Thanks.
  2. elkboy
    elkboy 1/2 ton status
    Aug 18, 2000
    293
    Hillsboro Oregon
    Measure the spring perches, I think you will find they are narrower on the van versions.
    [​IMG]<font color=red> Elkboy</font color=red> [​IMG]
  3. Stoopalini
    Stoopalini 1/2 ton status
    Oct 17, 2000
    999
    Austin, Texas
    There are two types of emergency brake cables. One type has the bolt on adapter, and the other has the press/snap in connector.
    Check out the type that is on your truck now (most likely the snap in) and then check the SF backing plates. If they are the same, it will work.
    When I did my 14B FF swap, I was lucky enough to get a 14B FF axle that had the snap in type of connector so I didn't have to change a thing.
    Thomas.
    -- '84 K5 Blazer --
    <A target="_blank" HREF=http://Stoopalini.coloradok5.com>http://Stoopalini.coloradok5.com</A>
