14 bolt ff disc brake brackets
Discussion in 'Vendor Forum' started by 85m1009, Sep 11, 2005.
  1. 85m1009
    85m1009 1/2 ton status
    Jul 11, 2000
    We now offer 14 bolt ff disc brake conversion brackets
    Our brackets are laser cut from 3/8" thick cold rolled steel. The notable difference in our brackets is that the threaded holes are actually drilled and taped on a mill unlike other brackets available on the market that have threaded holes that have been laser cut prior to tapping causing poor thread quality and poor bolt retention. To complete the conversion you will need to acquire a set of 3/4 front disc brake calipers and rotors from a mid 80's GM truck along with new brake lines.
    CK5 member pricing: :eek1: $50.00
    Call 660-831-0101 to order.
